(Nsw) Salisbury 3.08 to 3.55 or 4.11
Posted 02 December 2020 - 09:36 PM
Posted 03 December 2020 - 09:22 PM
Tons of commercial vehicles running 3.55 Salisbury's so finding a gear set should be easy. Just depends what kind of centre/axles you have/want.
If you tell me your exact rear tyre size and the overdrive ratio of the T5 (0.68:1 maybe?) I can run some speed vs. RPM numbers for you?
_Lazarus_
Posted 03 December 2020 - 09:24 PM
3.55 gears or centre will fit.
Posted 04 December 2020 - 07:20 AM
Posted 04 December 2020 - 08:37 AM
Posted 04 December 2020 - 12:22 PM
Plenty of UC Sunbirds with 3.9...
Posted 04 December 2020 - 12:26 PM
Posted 04 December 2020 - 12:43 PM
Small Salisbury are just disguised banjo. Lots of Gemini too with 3.9 IIRC too.
oops should've reread the first post!
Posted 08 December 2020 - 07:53 PM
Tonners were standard with 3.55, got 3.36 with V8 model if A/C optioned or an economy axle optioned. 4.44 came out into HJ for 6cyl manual (especially 4spd). 5.0L (auto only) got 3.36. That’s about it, basically only 3.36, 3.55 or 4.44.
Posted 08 December 2020 - 07:56 PM
Posted 08 December 2020 - 08:24 PM
https://www.ebay.com...kQAAOSwGJJftv~o
If your hemisphere or the donor is unserviceable worst case is you might have invest in one of these:
https://www.harrop.c...sbury-28-spline
Posted 09 December 2020 - 06:04 PM
Does the 3.55 gear set fit on the 3.08 Hemisphere?
I had a feeling the 2.78 and 3.08 shared a Hemisphere, 3.36, 3.55 and 4.44 shared a Hemisphere, and not sure where the 2.6 fits in with things.
Posted 09 December 2020 - 06:08 PM
Posted 27 December 2020 - 12:38 PM
quote name="yel327" post="1061770" timestamp="1607423051"]
Here is a diff with 3.55 gears:
https://www.harrop.c...sbury-28-spline[/quote]
