Girlock calipers.
28 replies to this topic
#1 Indy Orange
Indy Orange
  • 2,968 posts
  • Name:Paul
Posted 12 January 2021 - 11:45 PM
Hi all ,I have stock standard Girlock callipers on my LCGTR ,with 6" Sprintmasters ,the callipers are scraping on the inside of the rim ,only slightly making contact ,do I need spacers ? I thought these would bolt straight on with no hassles , thanks Paul.
Edited by Indy Orange, 12 January 2021 - 11:53 PM.
#2 claysummers
claysummers
  • 3,664 posts
  • Name:Clay
Posted 13 January 2021 - 06:44 AM
Thought they came factory with spacers. One of few cars they are legal on. Not that I'm an expert.
#3 S pack
  • 15,745 posts
Posted 13 January 2021 - 06:45 AM
The Sprintmasters should bolt straight on and clear the calipers. Not going to hurt to put one spacer on each each front wheel, should gain a little clearance.
#4 Indy Orange
Indy Orange
  • 2,968 posts
  • Name:Paul
Posted 13 January 2021 - 09:54 AM
Thanks guys! If the 6” Sprintmasters are designed to bolt straight on what could be causing the clearance problem with the calliper?
#5 yel327
  • 13,720 posts
Posted 13 January 2021 - 10:09 AM
Are they original GMH supplied Sprintmasters? Have you tried another rim?
#6 Indy Orange
Indy Orange
  • 2,968 posts
  • Name:Paul
Posted 13 January 2021 - 10:26 AM
No they’re Sprintmaster copies Yel ,CSA, I have original 5.5 rims so I’ll try one of those .
#7 Kockum
Kockum
  • 478 posts
Posted 13 January 2021 - 11:19 AM
I can see your problem - the stick on wheel weights.
#8 Indy Orange
Indy Orange
  • 2,968 posts
  • Name:Paul
Posted 13 January 2021 - 11:30 AM
Yeah Kockum, that was definitely one of the problems , I removed them , but still scrapes on the calliper.
#9 Kockum
Kockum
  • 478 posts
Posted 13 January 2021 - 11:38 AM
I had the same problem years ago, removed the offending weight and all good.
#10 claysummers
claysummers
  • 3,664 posts
  • Name:Clay
Posted 13 January 2021 - 11:58 AM
Can they be machined? I'm getting the backs of my Sampson's turned down 5mm to help guard clearance. $70 per wheel at Extensive Wheel Services in Adelaide.
#11 I'm a Red Motor fiend
  • 767 posts
  • Name:Adam
  • Car:LJ 4 door, LC GTR
Posted 13 January 2021 - 01:09 PM
Mine did this on my sprintmasters.
Angle grinder to caliper = clearance
#12 jd lj
jd lj
  • 2,119 posts
  • Name:James D
  • Car:LJ
Posted 13 January 2021 - 03:37 PM
CSA sprintmasters should go on std calipers without a problem. Sorry that I don't have an answer to the problem.
With my Volvo calipers and sprintmasters I need to make sure thin weights are used otherwise the calipers will knock them off.
#13 MFM
MFM
  • 687 posts
  • Name:Mark
  • Car:xu1
Posted 13 January 2021 - 04:52 PM
My Globe sprintmasters did the same but only on the weights they used, so they re-positioned the weights closer to the edge of the inner rim. Its pretty close tolerances in there between the caliper and inner rim.
#14 Indy Orange
Indy Orange
  • 2,968 posts
  • Name:Paul
Posted 13 January 2021 - 06:21 PM
Righto ,thanks everyone I'll invest in some spacers.👍
Edited by Indy Orange, 13 January 2021 - 06:22 PM.
#15 MFM
MFM
  • 687 posts
  • Name:Mark
  • Car:xu1
Posted 13 January 2021 - 06:43 PM
I have one (1) spacer on the front. Supposed to have 2 I believe?
#16 S pack
  • 15,745 posts
Posted 13 January 2021 - 07:17 PM
3 spacers on each front wheel Mark.
#17 MFM
MFM
  • 687 posts
  • Name:Mark
  • Car:xu1
Posted 13 January 2021 - 07:30 PM
Crikey? thanks Dave. Might have to buy a couple of reproduction ones as I have 2 on the back and one on the front which came with the car
#18 S pack
  • 15,745 posts
Posted 13 January 2021 - 08:02 PM
One spacer on each rear wheel.
#19 Ice
  • 15,213 posts
Posted 13 January 2021 - 08:10 PM
Why the spacers on the back ?
#20 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 13 January 2021 - 09:07 PM
Wheel tracking mate.
Are you sure that it's not 2 per front wheel & 1 per back wheel on early 72's Dave ? I should remember, but i don't atm.
#21 S pack
  • 15,745 posts
Posted 13 January 2021 - 09:27 PM
Marks XU1 should have 3 spacers on each front wheel.
#22 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 14 January 2021 - 06:06 PM
I need to get educated again Dave. Thanks mate.
#23 MFM
MFM
  • 687 posts
  • Name:Mark
  • Car:xu1
Posted 14 January 2021 - 07:25 PM
Silly question I think but is there any difference between the OEM spacers and reproduction ones? thinking repro will be metric thickness??but is there any visible difference? any suggestions? anyone want to sell me 4 x OEM spacers  :mellow:
#24 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 14 January 2021 - 07:49 PM
I have a set of spacers out of the lc xu1 atm actually, so if you like, i can measure the thickness of them.
You must have spacers in yours, or you couldn't have xu1 discs, unless they where really worn.
#25 MFM
MFM
  • 687 posts
  • Name:Mark
  • Car:xu1
Posted 15 January 2021 - 06:49 AM
Car came with 1 spacer on each front wheel and 1 spacer on each rear. I can measure my own which I think are OEM but just wanted to know whether the repro dimensions were the same. My original brake rotors were replaced in the early 80's by the bloke I bought the car off (mate)as they used to squeal loudly every time he braked so he got the shites and went and bought new ones from the local Holden dealer and replaced them, however he kept the original rotors which I also have.
