hi guys wondering best way to split my ignition wire.. wont to run msd tac water meth and fans on one wire how can i split the one wire safely.. is there a junction box that i could get ..or how others have done it ..any help would be great
ignition wire help
Posted 24 January 2021 - 11:40 AM
Posted 24 January 2021 - 12:31 PM
Posted 24 January 2021 - 12:58 PM
ok thanks will go to jaycar have a word with them
Edited by basicgreen, 24 January 2021 - 12:59 PM.
Posted 24 January 2021 - 05:43 PM
Hi
Running fans ignishion and other accessoreys from 1 wire may not be a good thing, Too much load for the ignishion wire. Even worse if you are planing to use the resister wire that feeds the factory coil.
I added a fused relay box to my car with seperate relays/fuses for the extra stuff (like in most later model cars), Fusabel link and heavey feed from the battery to the relay box and seperately fused outputs that are built in to the relay box. Trigger the relays from the origonal wiaring loom and the relays take the load. Reduces the load on the old switches and is a lot safer than overloading the exhisting system. I ordered the relay box on ebay and it came with relays and crimps to wire it up as needed.
If you do not want to go that far atleast relay switch the high load stuff so you do not overload the factory system.
