engine number retrieval .
4 replies to this topic
#1 _Chrisso_
_Chrisso_
Posted 29 January 2021 - 10:27 AM
Hi All ,I thought this may be of use , I  just found this attached PDF method for finding engine numbers if your motor has been decked/ Machined , I'm yet too try this but has anyone done it & how did you go? Cheers Chrisso
Attached File  Restoration of Eradicated Serial Numbers by an Inexpensive Electr.pdf   415.52K   119 downloads
#2 _Chrisso_
_Chrisso_
Posted 17 February 2021 - 07:59 AM
UPDATE : I've since done this process & it works , but you have to polish the area well and be very patient ,as you see numbers write em down , I used ultrasonic fluid instead of hydrochloric , I found a document from machinist with engine number on and she match's ,,,,,IT WORKS ,cheers chrisso
#3 CI 0308
CI 0308
  • 736 posts
  • Car:77 LX SS, VX SS
Posted 17 February 2021 - 10:31 AM
I might give this a try. I have a 308 block with a police number on it that I bought off gumtree and can see a few remnants of the 11QT number when I tried the heat method. The only thing that scares me is I might not like what I find when I check the number with the cops.
Sent from my SM-A705YN using Tapatalk
#4 _Chrisso_
_Chrisso_
Posted 17 February 2021 - 06:38 PM
I think 11qt is for HQ Statesman, the numbers will appear very ,very hazy and the surface needs to be polished free from scratches , so my method was a AA battery with 2 leads taped onto the battery + (positive) to the block and make a swab maybe a spare pushrod & tape a rag to one end ,try an alligator clip on the - (negative)as close to the swab/fluid end and lightly swipe it back n forth across number area ,good eyes and good lighting is needed as numbers are a ghost of what was there previously ,good luck fella
#5 CI 0308
CI 0308
  • 736 posts
Posted 17 February 2021 - 07:11 PM
Ill give it a try and report back. The block is in our storage locker so it might be a while. 11QT was from HQ right up until early 1979 so covered a few models.
