Oil cap breather how to clean
14 replies to this topic
#1 ljv8
ljv8
  • 299 posts
  • Name:Steve
  • Car:LC GTR
Posted 06 March 2021 - 09:06 PM
Hey all,
Has anyone worked out how to clean the crusty demons out of an original Holden 6 breather oil cap?
I have a couple that are extra gunky, and would love to get them clean for re-use since no-one does a reproduction.  I'm using an aftermarket one now but looks wrong, and would love to get mine clean, painted up and usable.
I'm thinking maybe an extended soak in petrol may work, soaking the first one below in de-greaser didn't work.  I was thinking to maybe pry open the lip to take it apart to replace the guaze, but worried I will stuff it.  Does anyone have any tips on de-gunking a cap, without destroying it?
Nice and rusty but the outside will be relatively easy to clean.
Attached File  OilCap01.png   363.16K   2 downloads
This one is probably worse, and if I was going to pry one open this is probably the one I will try.
Attached File  OilCap02.png   376.33K   3 downloads
This is my 2nd one which has less rust but plenty of gunk.
Attached File  OilCap03.png   322.54K   2 downloads
#2 Indy Orange
Indy Orange
  • 2,959 posts
  • Name:Paul
Posted 06 March 2021 - 09:16 PM
You can soak in phos acid and get rid or that rust or molasses ,prime and paint.Nah , don't pry it open ,soak in degreaser for a few days , blow it out with compressor , re oil with light oil .
Edited by Indy Orange, 06 March 2021 - 09:18 PM.
#3 S pack
  • 15,736 posts
Posted 06 March 2021 - 09:22 PM
Soak in kerosene for a few days.
#4 warrenm
warrenm
  • 2,119 posts
  • Car:1972 LJ Torana
Posted 07 March 2021 - 12:08 AM
If you are using a hydrocarbon based degreaser or petrol, leave it soak for a few days, water based may need longer.
As above, don't try to open it.
#5 ljv8
ljv8
  • 299 posts
  • Name:Steve
  • Car:LC GTR
Posted 07 March 2021 - 06:38 AM
Hey thanks guy's for the ideas much appreciated.  I think the degreaser I used must have been water based and didn't make much difference last time after soaking it for a few days.  Maybe it was a cheap crappy one, can't recall.
I had some kerosene so dropped it in a kerosene bath this morning, and after just an hour it's already showing signs of cleaning up really well.  Gunk is breaking down and I can start to see shiny gauze.  Dave's approach looks like it may be the winner in my instance.  Will check in a couple of days and post up the results.
#6 73SUNBURSTEXYOUWON
73SUNBURSTEXYOUWON
  • 819 posts
  • Name:JASO
Posted 07 March 2021 - 06:48 AM
Dont Chrome it, that will destroy the gauze inside.
#7 S pack
  • 15,736 posts
Posted 07 March 2021 - 08:45 AM
Every now and again give it a bit of a shake to swish the kero around inside and then tip it out into the kero bath. Put it back into the bath and let it soak some more.
When the kero bath is looking quite cruddy tip it out and put in fresh kero and repeat the process until clean.
Disclaimer: Ensure you dispose of the old kero in an environmentally responsible manner.
#8 bat 53
bat 53
  • 518 posts
  • Name:albert
  • Car:lc gtr
Posted 07 March 2021 - 09:43 AM
i used molasses took a week clean as a whistle
#9 claysummers
claysummers
  • 3,650 posts
  • Name:Clay
Posted 07 March 2021 - 11:42 AM
He means burn shit with it.
#10 claysummers
claysummers
  • 3,650 posts
  • Name:Clay
Posted 07 March 2021 - 11:46 AM
From memory the HK owners manual said to soak the cap in kero every oil change (3000 miles) and put some oil back in.
#11 73SUNBURSTEXYOUWON
73SUNBURSTEXYOUWON
  • 819 posts
  • Name:JASO
Posted 07 March 2021 - 12:33 PM
Recycle the Kero in your Kero burning Refrigerator, :)
#12 ljv8
ljv8
  • 299 posts
  • Name:Steve
  • Car:LC GTR
Posted 07 March 2021 - 03:03 PM
Ok have been swirling and shaking it out a few times.  Cleaning up real nice.  After repeating this for a couple of days and a kero change should be like new!  And I thought Kero was just for ancient lamps and tractors.
Showing what was the second cap in my original post that looking much cleaner has been soaking since this morning, next to the uncleaned one.
Attached File  CapPartialClean01.png   533.66K   3 downloads
Haha my thoughts about used Kero were the same, fire starter for the 44 gallon drum!
Edited by ljv8, 07 March 2021 - 03:08 PM.
#13 LXCHEV
LXCHEV
  • 3,629 posts
  • Car:'76 LX - 383 Chev
Posted 08 March 2021 - 08:40 PM
That looks excellent. Your other option would be to soak in white vinegar - I've been doing similar myself lately and it's been excellent at cleaning deep rust off various parts.
#14 ljv8
ljv8
  • 299 posts
  • Name:Steve
  • Car:LC GTR
Posted 11 March 2021 - 08:21 PM
Hey thanks all some great suggestions here.  I only ended up trying the Kerosene because I had it on hand, and it worked to perfection at breaking down the gunk.  I would image vinegar would probably also work well, and sounds like molasses works too.
Left to soak for a day, a bit of swirling here and there and shaking out any gunk.  The Kerosene was very dirty tipped it out and had a nice layer of grime in the bottom of the container.  Filled up with fresh Kerosene to soak overnight.  Next day did the same thing bit of a shake here and there throughout the day.  Put another batch of fresh Kerosene through it and it was coming out clean and blue after two full days.  Stripped off the old cracked paint and gave it a fresh coat of silver.
Super happy with the end result, came out like new and not a trace of gunk caught in the gauze.  Thanks Dave.
I'm now doing a cycle with the extra rusty gunky cap in the top photo.  Looks like it's going to take three days of soaking to fully clean, but its coming out nice too.  These caps probably had decades of build up, and now going to have two nice caps to choose from.
Cleaned and painted
Attached File  Cleaned01.png   627.82K   1 downloads
As you can see dirty kero on the left and fresh on the right.  It really gets in there and breaks down the grime.
Attached File  Cleaned02.png   444.61K   1 downloads
#15 warrenm
warrenm
  • 2,119 posts
Posted 12 March 2021 - 06:44 AM
I wouldn't use vinegar, I think it will eat the filter medium.
