Holden 308 fuel pump
2 replies to this topic
#1 kavesh
kavesh
  • 73 posts
  • Name:Kavesh Maharaj
  • Car:1971 Holden UTE (Chev El Camino - RSA)
Posted 30 March 2021 - 02:53 PM
Hi all
I am having issues with my quadrajet carb and trying to eliminate all possibilities.
I have stripped the carb several times and even had a carb rebuilder look at it.
Problem is initially the carb runs and idles fine. After a drive it won't idle as it should. Gets very erratic.
I would like to eliminate the fuel pump as a possible cause. My fuel pump is a mechanical pump and does seem to supply fuel adequately to the carb on face value.
If the fuel pressure is not adequate how will I know this? I do not have a fuel pressure gauge to test this.
I borrowed a gauge from a friend but he advised that it was designed for high fuel pressure applications and may not work. When I hooked it up, the needle did not move when the motor was idling. I hoped that it would have moved even a mm to suggest there is some pressure.
The pic was when the engine was idling.
I have an electric pump to try but really do not want to go that route.
Please advise.
#2 Shiney005
  • 9,712 posts
Posted 30 March 2021 - 03:10 PM
Holden or Chev motor?
#3 arrimar
arrimar
  • 3,134 posts
Posted 30 March 2021 - 03:27 PM
6psi is only 0.421kg/m2 so the gauge might be fine.
You need a gauge that reads from 0 up to 15 or 20psi so the desired pressure, say 4.5 to 6psi, is recognisable on the dial.
Too much pressure the needle might not seat properly causing a stumble at idle.
Is it an AC servicable pump or a new sealed replacement?
