Cast iron impeller water pumps
29 replies to this topic
#1 yel327
  • 13,717 posts
Posted 06 May 2021 - 08:51 AM
Just spotted that Auto Surplus is selling these for at least red V8 and most red 6. I knew they were out there but wasn't sure who made them.
https://www.autosurp...hz-wb-commodore
https://www.autosurp...ylinder-149-161
https://www.autosurp...161-173-186-202
#2 Ice
  • 15,212 posts
Posted 06 May 2021 - 10:29 AM
So a V8 pump which is bigger than the 6 cyl is cheaper
wtf
#3 yel327
  • 13,717 posts
Posted 06 May 2021 - 10:50 AM
Probably still made in higher volumes as lots of it would be common with the longer pump up until the end of VS. The 6cyl pump is a lot cheaper with the crappy impeller.
#4 hanra
  • 11,015 posts
Posted 06 May 2021 - 11:07 AM
I bought a Gates Water pump... but cant for the life of remember what the impeller looked like...  GWP808 is the P/N but that dosnt line up with anything on the Gates website..
Edited by hanra, 06 May 2021 - 11:07 AM.
#5 hanra
  • 11,015 posts
Posted 06 May 2021 - 11:17 AM
Gahhhh was on an american website...
https://www.gatescat...-au/gwp808.html
#6 claysummers
claysummers
  • 3,664 posts
  • Name:Clay
Posted 06 May 2021 - 11:18 AM
Interesting they quote one pump 1963 - 1969 for 6 cylinder, as the pulley and fan hole spacing changed at some stage between EH and HK. Don't ask me how I know.
You can always press on your original hub to the new pump, but then you could also press your original cast impeller on to a new pump you can buy for $25 at local parts shop.
early Holden nut
#7 hanra
  • 11,015 posts
Posted 06 May 2021 - 11:20 AM
I see there was talk some time ago that the impeller on the GMB brand cast water pump had the vanes facing the wrong direction?
http://www.gmh-toran...-v8-water-pump/
#8 Ice
  • 15,212 posts
Posted 06 May 2021 - 11:21 AM
Oh great i bought one of them last year still in the box though
#9 hanra
  • 11,015 posts
Posted 06 May 2021 - 11:23 AM
But I note in that thread the P/N was W1000 which appears to be for later model 308's?
WP808CG seems to be this units part number.
#10 hanra
  • 11,015 posts
Posted 06 May 2021 - 11:41 AM
Crack it open and get some pics
#11 Indy Orange
Indy Orange
  • 2,967 posts
  • Name:Paul
Posted 06 May 2021 - 11:53 AM
early Holden nut
I found a good second hand pump with a cast impeller and had the hub changed over to suit the pulley , haven’t started the car yet so I hope the pump is ok.
#12 mick_in_oz
mick_in_oz
  • 666 posts
  • Car:LX Hatchback
Posted 06 May 2021 - 08:04 PM
GMB pump made in Japan, Cast Iron Impeller, cheap!
Early/Red
https://www.ebay.com...&frcectupt=true
#13 Ice
  • 15,212 posts
Posted 06 May 2021 - 08:42 PM
Here you go Brad
Don’t know about made in Japan Mick
#14 mick_in_oz
mick_in_oz
  • 666 posts
  • Car:LX Hatchback
Posted 06 May 2021 - 08:48 PM
They used to be, unsure when they changed. I bought one a handful of years ago and I thought it still had made in Japan on it. I might go check my spare.
Either way, I've found the GMB to be of good quality, or certainly the few I've used over the years.
#15 hanra
  • 11,015 posts
Posted 06 May 2021 - 08:58 PM
Here you go Brad
Hard to tell which direction those vanes are going?
#16 Ice
  • 15,212 posts
Posted 06 May 2021 - 09:05 PM
To the right
#17 hanra
  • 11,015 posts
Posted 06 May 2021 - 09:16 PM
So the wrong way?
#18 Ice
  • 15,212 posts
Posted 06 May 2021 - 09:34 PM
So the wrong way?
I thought it was the right way ?
#19 hanra
  • 11,015 posts
Posted 06 May 2021 - 09:51 PM
So from reading the other post. The impeller rotates anti clockwise when sitting in the drivers seat.
I don’t know if this diagram is from in front or behind?
But again, I note yours is P/N: W1000? Yet the one on eBay is P/N: WP808CG???
Edited by hanra, 06 May 2021 - 09:53 PM.
#20 Shiney005
  • 9,710 posts
Posted 07 May 2021 - 12:04 PM
I've got a new W1000 here and the vanes curve the same way as my NOS single outlet one. The same as the one drawn on above.  GMB has 8. NOS has 6.
W1000 has long snout.
Edited by Shiney005, 07 May 2021 - 12:05 PM.
#21 hanra
  • 11,015 posts
Posted 07 May 2021 - 12:54 PM
Clears that up! So the W1000 is for later model 308's?
#22 Ice
  • 15,212 posts
Posted 07 May 2021 - 12:57 PM
I think these were for early 308 commodores
#23 hanra
  • 11,015 posts
Posted 07 May 2021 - 01:03 PM
This is what has confused me.
#24 hanra
  • 11,015 posts
Posted 07 May 2021 - 01:30 PM
Their text for P/N: WP808CG states that it is to suit models with P/N: 3947772 stamped into the fan...???? So its only for air con models? Which would have a viscous hub?
Edited by hanra, 07 May 2021 - 01:32 PM.
#25 hanra
  • 11,015 posts
Posted 07 May 2021 - 01:37 PM
Gahhhh.....
WP808CG for early 308  ??
W1000 for late 308/304 ??
