G-Pak
Posted 28 May 2021 - 06:49 PM
Posted 28 May 2021 - 06:57 PM
Colour is a good indicator but the better indicator is the seating capacity and L20 M20 GV4 on a VB69. Like a HQ SS the driveline and seating capacity on the budget level vehicle are dead giveaways, you are talking 1000’s to 1 odds with that driveline of it being a Gpak over a similarly optioned S.
Posted 28 May 2021 - 09:10 PM
Posted 29 May 2021 - 10:08 AM
hi the g pack colours as I remember were 3 colours only yellow red and green built in 2 batches feb 75 and I think nov 75 L20 eng m20 4 speed and slr gauges sports steering wheel etc etc as tony has said axle gv4 should be on the plate not gu4
Posted 29 May 2021 - 07:03 PM
L20 3300 (202) Hi-Comp 6 Cyl Engine M20 4-Speed Manual Transmission (3.05 1st Gear) GV4 3.36 Ratio Rear Axle JL2 Power Front Disc Brakes N70 5.50 JJ X 13 Steel Wheels 175SR 13 Radial Tyres 19V Black Vinyl Interior Trim - Early Series I 18V Black Vinyl Interior Trim - Late Series I 18W Black Vinyl Interior Trim - Early Series II XS6 Reclining Front Bucket Seats M11 Floor Shift Centre Console U63 Push Button AM Radio U21 Full Instrumentation (Oil, Water, Volts & Tacho) PO3(PA1 ?) Full Wheel Covers (SL/R Style) Sports Steering Wheel (SL/R Style)
Dr Terry
Posted 30 May 2021 - 08:27 AM
192976124_10214677366087896_5654003164554896574_n.jpg 47.29K
8 downloads1976 Holden Torana Plus 4 Diesel prototype in Petone. Engine was a 1.7 litre 4 cylinder, 0-100 was measured with a calendar..
Edited by wild orchid, 30 May 2021 - 08:28 AM.
Posted 30 May 2021 - 08:30 AM
Edited by wild orchid, 30 May 2021 - 08:34 AM.
Posted 30 May 2021 - 12:20 PM
Hi Dr T you have made a punching error the paint code for absinth yellow is 568-15949. overall You have made a really good rundown on the g pack.
Posted 30 May 2021 - 12:42 PM
As I said above, the easiest way to do it from tags is L20 M20 GV4 on an LH S with 5 seat capacity. I very much doubt you'll find any other LH S in this combination. Colour and Trim can help if it gets past that test, however trim might be problematic as they appear with all of 19V, 18V and 18W.
Posted 30 May 2021 - 03:18 PM
Well spotted.
I just did a copy & paste off some old data I had, so I completely missed the paint code error.
Dr Terry
