Apologies if I am flogging a dead horse, but I am not sure whether I should buy triple Weber’s or SU’s for my lj torana. The car currently has a Holley 350, though I would like to change it to Weber’s or SU’s to gain a bit more hp (plus it looks and sounds sick!! Lol). The car is not on the road yet and hasn’t been registered since last owner in 2007. The engine is a 186 which has had a Holden 202 crank fitted (making it a 202) and is bored 60 thou (which from what I have found online makes it a 208) with flat top pistons, yells terra valves, double valve springs, 179 low Comp head (as indicated by head casting - 7420081), extractors and exhaust. This is pretty much all I know of the engine (was all done by previous owner).
So considering what’s done to the engine, which carb do you guys think will compliment the car the most? Should I look out for anything in particular (ie particular model/size of carby etc). Thank you all in advance and I look forward to some advice/recommendations
