Squicky cross member rubber insulators - LJ
24 replies to this topic
#1 MFM
MFM
  • 687 posts
  • Name:Mark
  • Car:xu1
Posted 07 October 2021 - 05:06 PM
Just had the most of the front end bushes done and whilst he was at it the cross member to chassis rail rubbers (mounting insulators - 8 of them) but now they are both squeaking/creaking when you bounce the front end. Took it back to mechanic that fitted them and he tried to tension them up more but made no difference. He now wants to remove and apply rubber grease to them. Not questioning his knowledge just want to make sure this is what you are supposed to do and if not seeking suggestion/s.
#2 S pack
  • 15,763 posts
Posted 07 October 2021 - 05:11 PM
Is he 100% sure it is the crossmember to rail insulators that are squeaking?
There are 8 crush tubes that are inserted into the chassis rails. The crush tubes have a short sleeve of plastic approx 20mm inboard from each end.
If the plastic sleeves are worn away/deteriorated that may be the cause of the squeaking.
#3 MFM
MFM
  • 687 posts
  • Name:Mark
  • Car:xu1
Posted 07 October 2021 - 05:32 PM
Oh ok? didn't know they existed?He crawled under whilst I bounced the front and he seems to think its these making the noise. Could the tubes have fallen inside the rail when he removed the old ones or he has failed to line them up as he inserted the bolts?? Do you happen to have a photo of these Dave? The car is booked in for friday week for him to drop the bolts out . I have a workshop manual so it might show it in there
#4 S pack
  • 15,763 posts
Posted 07 October 2021 - 05:42 PM
There are retaining structures inside the rails so the crush tubes can't fall out into the rails and get lost. This is why they have the plastic sleeves to prevent them rubbing inside the supports.
I don't have any pics of the crush tubes but I 'll see if I can rustle some up.
Edited by S pack, 07 October 2021 - 05:48 PM.
#5 MFM
MFM
  • 687 posts
  • Name:Mark
  • Car:xu1
Posted 07 October 2021 - 06:13 PM
I just checked my workshop manual (see attached) it says to lubricate the rubbers so perhaps this will fix the issue? Disregard a photo Dave now I can see what you mean. So just to clarify something. These plastic crush tubes. If mine are rooted how would you know? What concerns me is that if you start torquing up the cross member bolts and the spacers are not there I'm thinking you could start collapsing the chassis rail?
Edited by MFM, 07 October 2021 - 06:21 PM.
#6 S pack
  • 15,763 posts
Posted 07 October 2021 - 08:05 PM
The crush tubes are steel and have a sort of thin plastic sleeve around each end to prevent metal to metal contact.
Rust can be an issue with the crush tubes. If your mechanic didn't put the crush tubes back it will be impossible to torque up the bolts without excessively crushing the rubber insulators.
#7 MFM
MFM
  • 687 posts
  • Name:Mark
  • Car:xu1
Posted 08 October 2021 - 06:58 AM
Thanks Gary. I'll brief him on this when we do the job. If the tubes are not in place when you torque down the bolts then it will be difficult to compress the rubbers properly  hence why they might be squeeking. Anyway thanks for your advice (again)
#8 S pack
  • 15,763 posts
Posted 08 October 2021 - 07:09 AM
I should have some pics of the crush tubes coming through today from another XU1 owner. Will post them up for you as soon as I can.
#9 LJ RB30
LJ RB30
  • 1,043 posts
  • Name:Trevor
Posted 08 October 2021 - 10:55 PM
Attached File  IMG_20211008_0001.jpg   198.94K   6 downloads
Here's my replacement i made many years ago out of flexible electrical conduit skimmed down in the lathe.
Oh by the way the nolathane bushes crumbled after about 7-8 years & have been replaced with superpro.
This pic is 22-25 years ago. F#@k im getting old  :thebird:
Edited by LJ RB30, 08 October 2021 - 10:58 PM.
#10 S pack
  • 15,763 posts
Posted 08 October 2021 - 11:59 PM
From the LJ Parts cattledog.
Attached File  Xmember rail crush tubes..jpg   52.96K   3 downloads
These crush tubes have been restored and the original plastic sleeves refitted.
The owner still has to set the correct position of the sleeves currently located right at the ends of the tubes.
The sleeves should be set at about 20mm in from each end as both ends of the tube penetrate into the rubber insulator bushes.
Attached File  Xmember rail crush tubes. 02.jpg   223.07K   2 downloads
#11 MFM
MFM
  • 687 posts
  • Name:Mark
  • Car:xu1
Posted 09 October 2021 - 07:23 AM
Thanks Dave. appreciate your help. Sorry for sounding ignorant as I'm not that mechanically minded, but are these metal tubes loose fitting inside the rail and the plastic sleeves keep them snug and the ends (which have the plastic sleeve) push into the chassis rubbers. I'm guessing my mechanic should have some idea of how these sit? thanks again mate
#12 S pack
  • 15,763 posts
Posted 09 October 2021 - 07:41 AM
Yes they just drop in through the holes in the chassis rails and the exposed ends of the metal tubes engage into the rubbers. You can see in the parts book illustration they have drawn the plastic sleeves onto the crush tubes.
Edited by S pack, 09 October 2021 - 07:44 AM.
#13 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 09 October 2021 - 09:30 AM
It's all good Mark, we have pulled these things apart so it makes sense to us. You will learn as you go. The chrush tubes only go in from the top basically when the insulator sleeves are fitted. They are a fairly tight fit. The plastic sleeves are very thin, if you do need me to get out the verniers & measure the difference over the weekend, I can ?
#14 MFM
MFM
  • 687 posts
  • Name:Mark
  • Car:xu1
Posted 09 October 2021 - 06:29 PM
Thanks Gary, I do think Dave is right in that the squeek/creaking is probably from these tubes because the mechanic was underneath my car as I was bouncing it and he seemed confused to exactly the point where the noise was coming from as he took quite awhile (I got exhausted pushing down on the radiator support panel) so I think it was probably reverberating from inside the rail rather than at the chassis rubber itself although he said he could feel the noise through his hand which was held on the rubbers. If I need replacement plastic sleeves to go on the tubes, I assume we just try and find something around the workshop that will be a suitable fit (snug) i.e thin PVC pipe/sprinkler hose?
#15 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 09 October 2021 - 08:18 PM
If i can find where i have my verniers & change the battery i can measure it accurately for you, but i think that the internal diameter of the sleeves is 5/8" or 15.9mm & the thickness would be close to 1/2 a mm thick, so they're pretty thin. Let me know if you need them measured. I measure things exactly how they are, so i won't give you rough sizes. I will give them in imperial & metric if needed.
#16 conway
conway
  • 13 posts
  • Car:lj xu1
Posted 09 October 2021 - 08:59 PM
Heat shrink over the crush tubes is the way to go.
#17 jd lj
jd lj
  • 2,120 posts
  • Name:James D
  • Car:LJ
Posted 09 October 2021 - 09:13 PM
+1 for the heat shrink. The tubes tend to get a bit rusty too so give them a once over on a wire wheel on the grinder and a coat of paint to seal them up prior to fitting the heat shrink.
#18 LJ RB30
LJ RB30
  • 1,043 posts
  • Name:Trevor
Posted 09 October 2021 - 10:59 PM
Heatshrink will definitely do the job.
I just didnt like how sloppy they were in the chassis rails and i wanted them to be more located before tensioned up.
#19 Strat
Strat
  • 89 posts
  • Name:Nick
  • Car:LJ Torana
Posted 22 November 2021 - 08:17 PM
Hi Dave, you mentioned there is 8 crush tubes , I see 4 in the photo you posted , whereabouts are the other 4 placed? Do you have any workshop manual pics ? Thanks
#20 S pack
  • 15,763 posts
Posted 23 November 2021 - 08:36 AM
Mate, apologies, my error. There are only 4 crush tubes but there are 8 rubber insulators.
#21 Strat
Strat
  • 89 posts
  • Name:Nick
  • Car:LJ Torana
Posted 23 November 2021 - 07:25 PM
Thanks Dave
#22 _LONA-CK_
_LONA-CK_
Posted 25 November 2021 - 04:21 PM
What rubbers did you use mark
Cheers gong
#23 MFM
MFM
  • 687 posts
  • Name:Mark
  • Car:xu1
Posted 25 November 2021 - 04:57 PM
John they came with the car in the paper bag. Figured them to be NOS as all the other suspension bushes were NOS.
#24 jd lj
jd lj
  • 2,120 posts
  • Name:James D
  • Car:LJ
Posted 26 November 2021 - 04:43 AM
Nothing like using a 50 year old rubber.😁
Rubber deteriorates with time, don't be afraid to use new good quality bushes.
#25 MFM
MFM
  • 687 posts
  • Name:Mark
  • Car:xu1
Posted 27 November 2021 - 08:04 AM
These were in perfect condition, in fact I was surprised when Dave told me what they were for because they were soft and figured they should be hard for what they are designed for. There was no deterioration at all. They would have been bought in the 80's.
