I've whinged about this before but there's got to be something that can be done about a diff whine. My car came with three LSD's as well as one in the car, so 4 in total. 3:55, 2 x 3:36 and 3.08. I had three of these fully reconditioned and they all whined at the same RPM (55-65mph) nothing before and nothing after. I'm currently running the Penrite 140 which is good when the diff is cold (no whine) but as it warms up it gets worse. Its worse under acceleration and quietens up a little bit when cruising and nothing on de-acceleration and its only at that specific rev range. I even took the three diffs to three separate diff specialists to recondition them thinking I might snag one that would get rid of it. A forum member sold me some gears saying they didn't whine in his wifes car and these are what are in it now as they are the best of the bad bunch. I'm getting pretty good at swapping centre's. I took two of the repairers for a drive and they says its definitely diff and not gearbox.
Is there a straight 140 or higher viscosity oil that can be used? something that will remain high when hot because I think the Penrite stuff is 90w140.
Someone said the housing could be bent or that the suspension bush rubbers are so hard from age its causing the diff harmonics to transfer/echo noise. I'd pay anything to make it go away. Any suggestions?
