Has anyone got a parts diagram for the brake distribution block, i'm trying to work out how to get it apart.Can the piston be tapped out through the front brake pipe hole?
![Photo](https://www.gmh-torana.com.au/forums/uploads/profile/photo-thumb-7722.jpg?_r=1416775643)
LJ brake distribution block
Posted 15 February 2022 - 12:34 PM
Posted 15 February 2022 - 02:16 PM
Rodney, there is a plug in the end of the housing. Undo that and the piston assy can be removed.
I haven't had one apart but a fine pin punch or similar tool could be inserted through the front brake pipe port to tap the piston assy out if it won't easily pull out.
May need to soak it in brake cleaner or metho for a while if it is being stubborn.
Posted 15 February 2022 - 02:46 PM
Thanks Dave, i've pulled that plug and it is very rusty in there so i think it will need a bit of help to get moving. i tried tapping it through the front port but it was solid, i will soak it and try again.
Posted 15 February 2022 - 04:14 PM
I got the frOcker apart, there were 2 seals in there which had crumbled into little pieces, can anyone confirm if these seals are just orings please
Posted 15 February 2022 - 05:30 PM
I'm about to undertake this job myself as the brake warning light won't go off irrespective of what I do, so my 'O' rings will also be rooted I suspect.
Posted 15 February 2022 - 07:23 PM
Posted 15 February 2022 - 07:50 PM
Definitely got to pull the switch out to dismantle.
Posted 15 February 2022 - 07:56 PM
BS010 x 2
Orings from Bearing Services
Posted 16 February 2022 - 04:41 AM
Thanks heaps Neil.
Posted 16 February 2022 - 06:26 PM
