steering rack bush
5 replies to this topic
#1 slack one
slack one
  • 55 posts
  • Name:Gary Carter
  • Car:looking for one
Posted 24 July 2022 - 04:25 PM
Hi all i have brought a steering rack bush for my uc rack. Not sure on how to fit it. Can someone give me some guidance on how to fit it in the rack. Thanks Gary.
#2 dron
dron
  • 132 posts
  • Name:Darren
  • Car:UC
Posted 24 July 2022 - 06:05 PM
Hi
    To do my rack I removed it form the car.
Remove the pinion shaft and bearings, drill, out the pin that locks the tie rod end nut.
Remove the tie rod, Bush end only
Remove the rack
Remove and replace the bush
Reinstall the rack
Reinstall the pinion and bearings after checking the preload and adjust the shims if needed.
Adjust the tie rod and drill a new hole for the lock pin
Fit the 1st boot
Fill with the correct amount of oil and fit the 2nd boot
I will try to find the book and post a copy of the how to if you like, not a hard job with a little practice but it is one that needs to be done right.
Interestingly my uc was missing the bush. With less than 69 000 Kms on it when I got it and with no sine of the tie rod ever being removed I suspect it may have never been installed. It passed inspection after I put the stroker in it I but was never quite happy with the steering so I rebuilt the rack and found the bush missing.
#3 slack one
slack one
  • 55 posts
  • Name:Gary Carter
Posted 24 July 2022 - 06:59 PM
That would be great dron if i can get some instructions on how it is done.Thanks Gary.
#4 dron
dron
  • 132 posts
  • Name:Darren
  • Car:UC
Posted 31 July 2022 - 11:33 AM
Hi
   I have sent you a private message, Could not work out how to attach the PDF files here
Darren
Edited by dron, 31 July 2022 - 11:34 AM.
#5 dron
dron
  • 132 posts
  • Name:Darren
  • Car:UC
Posted 31 July 2022 - 12:10 PM
Dont know about the page order but I finaly managed to convert, Reduce file size and upload the infomation
#6 slack one
slack one
  • 55 posts
  • Name:Gary Carter
Posted 31 July 2022 - 01:23 PM
Thanks dron much appreciated. Thanks Gary
