Ride height
14 replies to this topic
#1 Indy Orange
Indy Orange
  • 2,968 posts
  • Name:Paul
Posted 30 August 2022 - 08:58 PM
Hi all,i need a bit of advice here.I put the original GTR springs back in the car but somehow it seems to sit  high,Is there a difference in springs from front to back?Was awhile ago I installed them can’t imagine I put them in wrong ,anythings possible. They haven’t been re tempered.
If I had to replace them can anyone suggest suitable springs maybe slightly lowered that won’t make the tyres hit the guard (they were originally rolled and took time to un roll them) I just want some that makes the car sit nice ,without affecting 404 concession.Ta Paul.
Edited by Indy Orange, 30 August 2022 - 09:08 PM.
#2 73SUNBURSTEXYOUWON
73SUNBURSTEXYOUWON
  • 831 posts
  • Name:JASO
Posted 31 August 2022 - 06:38 AM
Arent the spring shapes different they surely couldn't go in ass about from front to rear.
The bottom tail of the front spring sits againts the pressing in the LCA, is that sitting right and not contributing to a higher ride height look at front.
#3 RallyRed
  • 8,180 posts
Posted 31 August 2022 - 06:42 AM
Hi Paul,
Looks nice.
I dont think you can put the rear ones in "wrong".
the front ones need to have the end of the spring coil line up with the divet in the lower control arm ( as you prob. already know).
Regarding replacement springs, I think Lovells and Pedders still do them, but unfortunately I hear that Kings no longer offer the "send us the details of the spring you want, and we will make it" service.
Kings still do offer the KHFL-08 and KHRL -09 ( front and rear lowered ) springs I understand.
Pics to follow.
#4 73SUNBURSTEXYOUWON
73SUNBURSTEXYOUWON
  • 831 posts
  • Name:JASO
Posted 31 August 2022 - 06:52 AM
From Lj parts cat, the 4 cyl suspension image as example has a clear view of spring tail and pressed shoulder in LCA, the 6 cyl rear spring shape is different to front.
#5 S pack
  • 15,745 posts
Posted 31 August 2022 - 07:03 AM
Paul, what shocks are you running? I could probably find them in your build thread but I'm too lazy to look ATM.  :)
#6 Heath
  • 18,401 posts
Posted 31 August 2022 - 09:04 AM
Looks like it's ready to tackle the Simpson desert.
If you like the spring rates, you could get the rears re-set an inch lower and cut maybe 3/4" of free length off the fronts?
#7 MFM
MFM
  • 687 posts
  • Name:Mark
  • Car:xu1
Posted 31 August 2022 - 11:35 AM
Been awhile since I used gas shocks but I do recall they can raise the height a bit but probably not to the extent of your photo. My car visually appears to sit low in the bum as per the car photo from Rallyred and it has the original springs and Koni Classic oil shocks. I tried to sit a steel ruler level with the top of my rear tyre/mudgeard lip but the top of the tyre sits about 10mm up inside the guard so couldn't measure that distance.
#8 S pack
  • 15,745 posts
Posted 31 August 2022 - 12:56 PM
Spot on Mark, esp the relatively light rear end on the LC/LJ.
Edited by S pack, 31 August 2022 - 12:58 PM.
#9 sibhs
sibhs
  • 2,721 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 31 August 2022 - 06:53 PM
Did you tighten all the front end bolts/nuts after engine in so you don't bind up on the bushes?
Marty
#10 RallyRed
  • 8,180 posts
Posted 31 August 2022 - 07:06 PM
Marty
..and nip up the inner LCA bushes only after the car is back on it's wheels?
#11 Indy Orange
Indy Orange
  • 2,968 posts
  • Name:Paul
Posted 31 August 2022 - 07:46 PM
Thanks for the replies fellas ,so did some quick measurements,passenger front 320 ,drivers front 310,passenger rear 310 ,drivers rear 300,The springs are sitting right Jaso.
Ive got Monroe shockeis all round Dave.I’ve done all the tiightening and nipping up ,the only thing left to do is a decent wheel alignment because I took all the shims out for zincing and not back in order.
your car sits nice Col, that’s what I’m after.It’s got to be the springs as they are original GTR ones ,but I’m sure it sat better than that before resto.Sorry about picture quality.
Edited by Indy Orange, 31 August 2022 - 07:52 PM.
#12 Indy Orange
Indy Orange
  • 2,968 posts
  • Name:Paul
Posted 31 August 2022 - 08:22 PM
Seems there’s only 10 mm give or take in them.
#13 Indy Orange
Indy Orange
  • 2,968 posts
  • Name:Paul
Posted 31 August 2022 - 09:21 PM
https://www.ebay.com...XcAAOSwr7ZW8TA2
Thinking of purchasing these,will lower the car by 30-35mm ,I have 205 tyres,any ideas if they will hit the top of the guard? and could it effect 404 concessional license ?
#14 sibhs
sibhs
  • 2,721 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 01 September 2022 - 06:13 PM
These are the springs I first put in LJ. I’ve got 30mm lower written on them. They were too high for me so I went next stage lower. These should be ok for you Paul. I’m going to use them in Sally’s LC.
Marty
Edited by sibhs, 01 September 2022 - 06:15 PM.
#15 Indy Orange
Indy Orange
  • 2,968 posts
  • Name:Paul
Posted 01 September 2022 - 06:31 PM
Thanks Marty,I’ll get them.
