Hey all,
Does anyone know how many SLR & SLR 5000 there was made?
Also was the "HR" engine prefix for the SLR only or all L32 Torana's?
Trying to get some history on a car I own.
J.
Posted 04 November 2022 - 12:28 PM
Hey all,
J.
Posted 05 November 2022 - 07:00 PM
No idea on build numbers but HR was the prefix for any 253/4.2 L32 Torana.
Dr Terry
Posted 07 November 2022 - 10:44 AM
Thanks Dr Terry.
From what I understand HR (High Com) & HS (Low Comp) were the L32 prefix
Was HR only on SLR L32 or was it any L32?
Just trying to gather info on a car I have.
Joe
Posted 07 November 2022 - 08:30 PM
L32 is the RPO code for the high comp 253 V8
L33 would be the RPO code for a low comp 253 except I've never seen one in a Torana, it's possible some export models got a low compression engine but they were mostly used in commercial vehicles.
The "H" prefix signifies an LH, LX or early UC Torana red motor. All H prefix engines came out in a Torana, although not all Torana engines had an H prefix...
The second letter "R" signifies a high comp 253 V8, so no, they weren't only used in SL/Rs. Any 253 V8 Torana would've had a "HR" prefix.
If you're really looking to gather information on your car in particular then I'd suggest talking to Holden Historical Services about ordering a production report. They're well worth the money IMO.
Posted 08 November 2022 - 09:04 AM
Correct, L32 is the hi-comp 253/4.2 V8 & L33 is the lo-comp version, but to my knowledge the L33 was never offered in a Torana, so I very much doubt that the prefix HS ever existed.
AFAIK it was only offered in the HQ/HJ with a QS prefix (or 11QS for a base Statesman, which would have been ultra rare).
Dr Terry
Posted 08 November 2022 - 01:04 PM
Thanks for the info gents.
I did have a production report from HHS but it didn't give any other details that I didn't already know except for the car being sold at a John A Gilbert Dealership in Camperdown.in May 1974
I was told by RMS that this car was first registered in NSW in 1992 and then cancelled in 1993. From what I know its been sitting in a container ever since. Trying to find out where its been beforehand is very hard.
If it wasn't a genuine SLR I wouldn't care so much but I think trying to find its history would be beneficial.
I'll keep trying
Posted 08 November 2022 - 01:18 PM
So would that be Holden dealer number 025?
It's a bit funny that it was sold in Sydney in 1974 but not rego'd in NSW until 1992. I'd guess that means it went interstate, or perhaps had the wrong dealer code attributed to the sale?
I can't remember the details but I believe one of the big Torana clubs in Melbourne had registration records for Victorian registered SL/Rs (if it even was), hopefully somebody else here has a better memory than me?
Posted 08 November 2022 - 01:31 PM
It didnt have a dealer code. Just says John A Gilbert PTY LTD Camperdown.
I found it strange also. My only thought was it was purchased interstate also. Seems a little un real to be sitting for 20 years unregistered and then registered in 92 and cancelled in 93
It is a Melbourne built car after all.
Posted 08 November 2022 - 02:15 PM
That doesn't mean anything... with the exception of a couple of early prototypes (which I believe were built in Adelaide), all LH, LX & UC were built in Melbourne.
Posted 08 November 2022 - 03:12 PM
Oh right I must be wrong but always thought the A or B or S or M in front of the Chassis number (and on the tag) referred to its assembly location?
Posted 08 November 2022 - 03:56 PM
The letter on the end of the chassis number denotes the build plant, as in "M" for Melbourne.
The leading letter denotes the ADR (Australian Design Rules) revision. Whenever there was a change (or addition) of ADRs part-way through a model run they started a new revision.
So you knew that all "ALHxxxxxxM" cars complied to one set of ADRs, and all "BLHxxxxxxM" cars to another, as there could be different parts required to meet different ADRs.
Posted 09 November 2022 - 11:44 AM
Copy that
So correct me if I'm wrong. The numbers after the "ALH" are in numerical order? Say example ALH004001M was the 4001st built in Melbourne?
Posted 09 November 2022 - 11:59 AM
Well, yes and no.
For the most part I'd say yes, but it's not an exact science. The chassis numbers were stamped sequentially early in the body assembly process but the bodies weren't necessarily placed on the assembly line in sequential order.
Plus, if there was a problem with a particular car it would be pulled off the line to keep things moving, then repaired and re-inserted later on. Or if it needed personal attention (race shells, special builds "walked down the line", etc.) then it may not go on the line until much later.
Posted 09 November 2022 - 12:08 PM
Ok, cool thank you
