Coolant and flush
8 replies to this topic
#1 Johno
Johno
  • 217 posts
  • Name:John
  • Car:LX Torana
Posted 23 December 2022 - 03:13 AM
Just flushed my whole engine with water, replaced water pump and thermo. Engine is 308 stroked to 355 with an original HQ radiator (I think).
I have two questions:
* What coolant and antifreeeze do you recommend? I’m in Canberra so it hits negative zero here. Planning on using a concentrate and topping up with demineralised water.
* Do I need to flush it first with anything to remove any residue of previous coolant? If so, what would you recommend?
Thanks legends!
Edited by Johno, 23 December 2022 - 03:19 AM.
#2 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 06 January 2023 - 04:53 PM
Yes, flush the old coolant out. I have seen coolant turn to jelly because of the different chemical structures of different brands. Use 100% coolant and just stick to the one brand.
#3 yel327
  • 13,714 posts
Posted 06 January 2023 - 05:30 PM
Agree, make sure its properly flushed. Might mean pulling the water pump off to do it properly. I don't use coolant in my HJ, just rust inhibitor. But where you are antifreeze might be a good idea.
Note that a 308 strokes to 350ci/5.7L not 355ci/5.8L, of no relevance to your coolant though.
#4 dron
dron
  • 132 posts
  • Name:Darren
  • Car:UC
Posted 06 January 2023 - 05:43 PM
+40 stroker is 355, Every kit I have seen runs the +40 pistons unless specialy ordered
Any good glycol coolant, Stick to 1 type and no stronger than 50/50 if you go with the concentrate. to strong is not a good thing. Can be just as bad as running nothing at all
Edited by dron, 06 January 2023 - 05:46 PM.
#5 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 06 January 2023 - 05:45 PM
Why would you want to remove the water pump? Is there an area where the coolant can get trapped and not flush out properly?
#6 yel327
  • 13,714 posts
Posted 06 January 2023 - 05:58 PM
I found with my Premier that it wouldn’t flush properly without removing the water pump. Once it was off heaps more cr@p came out, not just old coolant but sludge and crud.
#7 yel327
  • 13,714 posts
Posted 06 January 2023 - 06:05 PM
+40 is actually 357ci. +30 on a standard SBC or Holden 350/5.7 becomes 355ci. But the standard SBC or Holden V8 size is 350ci.
#8 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 07 January 2023 - 01:42 PM
Tanks for that Yel!
#9 Johno
Johno
  • 217 posts
  • Name:John
  • Car:LX Torana
Posted 14 January 2023 - 10:54 PM
Thanks all, did the flush with water pump removed.
