304 Intake Manifold - Gaskets + Port Queries
3 replies to this topic
#1 LXCHEV
LXCHEV
  • 3,637 posts
  • Car:'76 LX - 383 Chev
Posted 28 June 2023 - 04:33 PM
Would love some advice here....
About to drop the intake manifold back onto a 304 V8. Project car. Came with brand new intake gaskets (unknown brand) - as pictured below.
Questions:
1. The bulges/raised seals around the intake ports, are different around the water ports (they only go half way around). If you visualise them going all the way around, it seems they'd hit the bolt holes, so this seems quite intentional to me. Thoughts? Looking online, other brands of gaskets have full seals... so I'm just wary....
2. Assuming I use these (which I'd like to) - should I add a thin smear of gasket goo (ultra blue/grey/black etc) around the water ports for added security? Or would you trust them bone dry?
3. Why are the rear water ports blocked off on these gaskets? There are water ports in the heads, and in the intake manifold.
I have also found a seller on ebay, listing Brand New Old Stock GM gaskets - which look identical to these ones of mine. The partial bulges around the water ports, and also the blocked off rear ports. So I'm assuming this is indeed factory spec?
Attached File  304 Intake Gaskets 1.jpg   183.36K   2 downloads
Attached File  304 Intake Gaskets 2.jpg   130.14K   2 downloads
Attached File  304 Intake Gaskets 3.jpg   152.48K   2 downloads
And lucky last - here is the ebay one I found for the NOS GM ones:
Attached File  304 Intake Gaskets - GMH NOS.JPG   64.48K   2 downloads
Edited by LXCHEV, 28 June 2023 - 04:35 PM.
#2 rexy
rexy
  • 3,758 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 28 June 2023 - 06:15 PM
I suspect the water port arrangement is so any leak is preferentially directed to the outside world rather than the valley.
I have always used a little permatex 3 (the old Aviation form a gasket) but I notice Dandy engines used a small amount of silicone around the water ports on my BBC.
#3 LXCHEV
LXCHEV
  • 3,637 posts
Posted 28 June 2023 - 07:31 PM
Thanks rexy. I'm going to use a very conservative amount of whichever gasket goo I have in the box of parts - just around those water ports.
I had a closer look at the intake manifold rear water ports and realised they don't go anywhere, so that explains why the gaskets are blocked off at the rear at least.
#4 ozyozyozy
ozyozyozy
  • 952 posts
Posted 02 July 2023 - 07:51 PM
Little gasket goo(grey, blue) around the coolant port and it will be fine. The genuine style of gaskets are the better ones to use.
