308 Pattern for Celica 5 speed
7 replies to this topic
#1 Johno
Johno
  • 217 posts
  • Name:John
  • Car:LX Torana
Posted 18 July 2023 - 07:08 PM
Hi Legends,
Can anyone please tell me what pattern a 308 needs to be to be mates to a celica 5 speed gearbox?
#2 dron
dron
  • 129 posts
  • Name:Darren
  • Car:UC
Posted 18 July 2023 - 07:38 PM
Have a look at what bellhousings Dallow or Castle Main do. That will tell you what block they will fit. I would expext both holden and turbo housings would be available at a guess
#3 Johno
Johno
  • 217 posts
  • Name:John
  • Car:LX Torana
Posted 18 July 2023 - 09:21 PM
The attached pic says turbo pattern
#4 yel327
  • 13,674 posts
Posted 19 July 2023 - 01:35 PM
In some cases where the clutch mech attaches using two bellhousing bolts you need a manual block, but otherwise it doesn’t matter. CRS bellhousing is often a multi fit anyway. The clutch mechs that use bellhousing bolts are V8 Torana and HX through to about 7/78 HZ V8.
#5 Johno
Johno
  • 217 posts
  • Name:John
  • Car:LX Torana
Posted 27 July 2023 - 07:32 PM
Sorry what’s a “manual block”?
#6 claysummers
claysummers
  • 3,642 posts
  • Name:Clay
Posted 27 July 2023 - 07:41 PM
Australian bellhousing pattern suit trimatic, ironically, and Aussie thre3 an$ four speed.
#7 rexy
rexy
  • 3,740 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 29 July 2023 - 03:06 PM
The only bellhousing I have for steel case to holden V8 is trimatic pattern.
Attached File  IMG_0838.jpeg   73.82K   4 downloads
Attached File  IMG_0837.jpeg   74.73K   2 downloads
Attached File  IMG_0835.jpeg   92.98K   2 downloads
Should pop up from time to time on EBay etc.
#8 yel327
  • 13,674 posts
Posted 29 July 2023 - 03:38 PM
They are almost always too thick on that bottom RH side bolt so won’t work with Torana or HX clutch mech. You have to modify/destroy an original clutch mech or convert to hydraulic or cable.
