holden 6 sandwich plate rod shop bellhousing
7 replies to this topic
#1 salamiman
salamiman
  • 131 posts
  • Name:Bruce
  • Car:LJ 2 door tribute
Posted 13 August 2023 - 10:15 AM
Hi All,
Wondering whether the holden 6 sandwich plate is used when fitting a CRS rod shop bellhousing.
Asked the question to them & said it should be removed??
Done a mock bolt up yesterday without the plate, it leaves large openings at the top on both sides of where the engine & bellhousing meet, usually closed off by the plate.
Says to me that it should be left in place.
Any help appreciated.
Bruce.
#2 Dr Terry
Dr Terry
  • 3,325 posts
Posted 13 August 2023 - 06:02 PM
I don't know of any Holden 6 bellhousing which excludes the sandwich plate. As you've pointed out, it's there for a reason.
Dr Terry
#3 Bruiser
Bruiser
  • 863 posts
  • Name:Bruce
Posted 13 August 2023 - 06:56 PM
Did you try mocking it up with it in there?
#4 salamiman
salamiman
  • 131 posts
  • Name:Bruce
Posted 13 August 2023 - 08:33 PM
Thanks for the replys fellas
I reckon the guy from CRS might be thinking of some other plate??
Didnt use the word sandwich, did say thin spacer between bell & engine.
Also would think its needed for correct starter spacing?
The CRS bell looks no different std ,in relation to how it connects to engine.
The sandwich plate would just move everything to the rear a couple of mm, and cover all the gaps.
Ill contact them again tomoz, but looks like the plate has to be there.
#5 salamiman
salamiman
  • 131 posts
  • Name:Bruce
Posted 13 August 2023 - 08:55 PM
Not a great shot, all I have atmAttached File  IMG_20230812_180341~2.jpg   165.42K   10 downloads
#6 warrenm
warrenm
  • 2,118 posts
  • Car:1972 LJ Torana
Posted 14 August 2023 - 06:47 AM
The sandwich plate also locates the starter motor.
#7 salamiman
salamiman
  • 131 posts
  • Name:Bruce
Posted 14 August 2023 - 08:53 AM
Thanks Warren
Sent an email to Jake @ CRS this Morn.
Thinking this is a mistake for sure.
#8 salamiman
salamiman
  • 131 posts
  • Name:Bruce
Posted 14 August 2023 - 12:44 PM
Yep Mistake, plate has to stay!
Thanks for everyones help.
