Wiper motor cogs
10 replies to this topic
#1 sibhs
sibhs
  • 2,720 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 02 September 2023 - 11:14 PM
One part that I think is getting harder to find is the plastic gear in the wiper motors. Most of these are cracked or broken and one day there won't be any left.
As some of you know I play around with resin moulding as a side interest so I decided to try and remake this part. It's the most complicated piece I've attempted yet and I've invested in a pressure pot to get better results.
Due to the nature of the part the cog needs to be cast onto the axle shaft using a two part mould and the axle and cog have to be lined up to get the park position correct. Anyway here's a few pics of my second attempt which I'm now going to let fully cure before testing it in a motor and running it under load for a time period.
I'm focusing on the Lucas motors which so far have two different cog variants. If this version succeeds I will track down a good sample of the other style and make those as well. Pictured below is my copy and the original.
I will keep you updated on test results.
Marty
Attached File  IMG_3347.jpg   106.27K   8 downloads
Attached File  IMG_3348.jpg   170.91K   6 downloads
Attached File  IMG_3349.jpg   257.08K   5 downloads
Attached File  IMG_3350.jpg   203.57K   5 downloads
#2 S pack
  • 15,731 posts
Posted 02 September 2023 - 11:36 PM
You are a very talented man Marty.
Sally is lucky to have a man who is so good with his hands.
Edited by S pack, 02 September 2023 - 11:36 PM.
#3 claysummers
claysummers
  • 3,643 posts
  • Name:Clay
Posted 03 September 2023 - 07:51 AM
Polyester resin Marty?
#4 Indy Orange
Indy Orange
  • 2,951 posts
  • Name:Paul
Posted 03 September 2023 - 08:41 AM
Made in Australia.👍
#5 LJ RB30
LJ RB30
  • 1,039 posts
  • Name:Trevor
Posted 03 September 2023 - 11:03 AM
Very nice job mate.
Interesting to see how it performs 👍
#6 rexy
rexy
  • 3,741 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 03 September 2023 - 12:28 PM
Now that’s impressive.
#7 gad05
gad05
  • 421 posts
  • Name:Graham
  • Car:73 lj 2 door , 74 lj sedan.
Posted 03 September 2023 - 02:19 PM
Nice work Marty.
You’re keeping our torana dreams alive!!!
#8 lctriples
lctriples
  • 414 posts
  • Name:paul
  • Car:LC 2 door, HR prem wagon
Posted 03 September 2023 - 04:36 PM
Hey Marty, looks like a brought one! Thanks paul (got your PM)
#9 308 Sunbird
308 Sunbird
  • 975 posts
  • Name:Stuart
Posted 04 September 2023 - 01:52 PM
Better than original Marty.
#10 Rockoz
Rockoz
  • 4,044 posts
  • Name:Rob
Posted 04 September 2023 - 03:09 PM
Can recall someone doing this with speedo cogs a while back.
Not sure it ended well.
Different material perhaps?
Hope it works though.
Rob
#11 sibhs
sibhs
  • 2,720 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 04 September 2023 - 06:11 PM
I'm leaving this alone Dave.
Poly eurothane
Rob
I'm hoping this works out Rob. Investing a bit of time and money into it. Be a shame if it just chewed the teeth off.
Thanks for the positive comments guys. I've greased the cog and fitted it. Connected it to 12v and ran it for 3 mins. Started applying load with my hands and so far it's great. The more load I apply only slows the motor down. I'll leave it in grease for a while and continue to test. Then remove cog and check for wear or damage.
Marty
Attached File  IMG_3420.jpg   130.03K   3 downloads
