202 into a lc 4 door
2 replies to this topic
#1 tsn007
tsn007
  • 1,019 posts
  • Name:Tony
  • Car:LX hatch, LX sedan
Posted 17 October 2023 - 06:50 PM
can you legally register a 202 in a 1971 Torana LC 4 door in NSW
#2 yel327
  • 13,678 posts
Posted 17 October 2023 - 07:01 PM
Have a read on the NCOP parts 3:
https://www.infrastr.../bulletins/ncop
It says you can go up to 120% power with a similar engine. A 202HC is only about 15% power increase over a 173HC, and similar mass. So in theory it doesn’t require engineering. But you should check first. If you used the LC XU1 power as your reference then a mild 202 should also work. But you’d need any associated mods like the brakes etc. But again, check first!
#3 warrenm
warrenm
  • 2,118 posts
  • Car:1972 LJ Torana
Posted 18 October 2023 - 06:27 AM
Yes you can fit a 202 into an LC legally.
