Hi all, I have the old style spring ring type leads on my car with a AC Delco battery,the problem I’m finding is the rings won’t grip the battery posts properly,they tend to rise up ,makes it worse with a bit of grease on as they are tapered.Any advise appreciated thanks .
Battery leads.
Posted 22 October 2023 - 07:27 PM
Posted 22 October 2023 - 07:43 PM
Posted 22 October 2023 - 08:13 PM
Don’t know how a thread would go in that metal I think it could be too soft.
Posted 22 October 2023 - 08:19 PM
Posted 22 October 2023 - 08:30 PM
Thanks Clay,it’s an option.
Posted 22 October 2023 - 08:44 PM
Squish them up a tad with multi-grips and don't put grease on them
Posted 23 October 2023 - 06:16 AM
Hi exactly as rodomo has stated squish them with multi grips, or u can remove leads and put in a vice, at worst again remove leads put on something solid and tap them with a hammer, I also have used a screw back in the day
Posted 23 October 2023 - 08:08 AM
Use a center punch and hammer to burr the inside of the clamps in several places.
Posted 23 October 2023 - 10:06 AM
Thanks guys, I’ll get rid of the grease for a start.
Posted 23 October 2023 - 10:40 AM
I have used these terminal covers to solve a problem like this
https://www.ebay.com...:Bk9SR_D2wZ_rYg
Posted 06 November 2023 - 11:31 PM
Are these the US manufactured ones, or the local ones? The local ones have an Australian Patent Number cast into the top.
Edited by GM5735, 06 November 2023 - 11:33 PM.
Posted 07 November 2023 - 06:34 PM
Local ones Geoff.
Posted 07 November 2023 - 11:09 PM
If they don't grab the post properly, it could be the post itself, being worn, or not being a 1:9 SAE 537 taper. There are a few batteries around which are not an SAE 537 taper.
It could also be that the battery lead itself has the internal contact pads missing, due to being removed from the battery post by twisting, or being hit with the tapered reamer so beloved of auto electricians.
There were also some reproduction made some years ago that were made without the contact pads, and they just plain don't work.
That's what the patent number on the terminal is all about, by the way. The function and presence of the pads inside the terminal.
pads.jpg 149K
2 downloads
SAE537 battery post dimensions.jpg 80.49K
3 downloads
Posted 08 November 2023 - 06:37 PM
Think I unfortunately have the repos without the contact pads Geoff.☹️
Posted 09 November 2023 - 05:56 AM
Think I unfortunately have the ryepos without the contact pads Geoff.☹️
Where were those leads from Paul?
I too have spring ring type terminals (repro) on my car, but have not had issue with them coming loose or gripping, i cannot confirm if my terminals have the internal pads.
Mine were made by ReprosRus.
Posted 09 November 2023 - 06:22 PM
Purchased off EBay Jaso,October 2020 ,so I suspect the early repo type as Geoff mentioned.
