ticking/rattling 253
#1 _oikurtman_
Posted 06 September 2006 - 10:45 PM
He said not to worry to much about it and try running something like 30W-50 oil to try quieten it, but i don't think I can stand it much longer.
i'm guessing the cheapest and easiest option to start with is the tappets? how should i go about this? what's involved?
i'm hoping i won't have to replace the heads, cam and lifters just to sort this problem, otherwise, I'm thinking I might as well rebuild the whole thing while I'm at it...
Posted 06 September 2006 - 11:07 PM
Edited by rodomo, 06 September 2006 - 11:08 PM.
Posted 06 September 2006 - 11:40 PM
then if not satisfied go with new lifters and a new mild cam.
#4 _LX8VD69_
Posted 06 September 2006 - 11:42 PM
#5 _oikurtman_
Posted 07 September 2006 - 10:54 AM
Cam guy quoted me $440 for a stage 1 cam, new lifters and a new double row timing set. He said most likely will cure problem and will make a huge difference in performance.
Head guy quoted me $660 for a pair of reco heads. (same as 308 heads aren't they?)
Should I do both or just try cam and lifters first? (Good prices?)
My dilemma is, while the intake manifold is off, i feel i should do the heads, and if the heads are off, i might as well spend the extra $500 on a rebuild kit and do the bottom end too. I suppose the only things stopping me are money and the fact that I'd have to pull the engine out again...
Edited by oikurtman, 07 September 2006 - 10:55 AM.
#6 _[BOTTLEDUP]_
Posted 07 September 2006 - 06:43 PM
If you are getting the heads reco'd then pay an extra $100 and get some decent valve springs fitted as well, say a set of Crow 4830s, which will let you run a slightly larger cam (5666)
Posted 07 September 2006 - 06:52 PM
Before u do all this, Whats ur oil pressure like? i had noisy tappets on my old engine cos the oil pressure wasnt up to scratch! do u have a gauge or a dash light?
#8 _oikurtman_
Posted 07 September 2006 - 07:02 PM
the motor has done around 400,000 kms.
its a lot of money (for me, student) and a lot of time and effort.. i have my doubts.
cheers.
Posted 08 September 2006 - 07:45 AM
This type of noise could be exhuast manifold gaskets, flange gasket, cracked exhaust manifold or even head gasket if it still has steel shim head gaskets. Get a mate to hold a rag blocking the exhaust and listen for the noise to get louder at idle.the ticking is there always at idle and always turns to rattle when revving, under load especially.
Good Luck!
Posted 08 September 2006 - 08:13 AM
#11 _[BOTTLEDUP]_
Posted 08 September 2006 - 12:43 PM
I'd not spend a cent on it if that is an accurate km reading.the motor has done around 400,000 kms.
Start saving for a rebuild or a good second hand engine.
Posted 08 September 2006 - 01:59 PM
Im with him, if its 400,000k its not worth sticking a new cam and lifters into, unless you do a full rebuild, or you could spend $200 on a decent 253,Sep 8 2006, 12:43 PM]
Posted 08 September 2006 - 11:49 PM
Its a boat anchor
Posted 08 September 2006 - 11:57 PM
#15 _Keithy's_UC_
Posted 09 September 2006 - 06:47 PM
Ahh well...
Goodluck mate!
Keith
Posted 09 September 2006 - 06:51 PM
You sought of need about 10psi for every 1000rpm, so at idle it should be about 8psi....
My 290 sits at about 10-20psi at idle.
But you could even find an 253 on ebay or the trado for next to nothing that would have done under 100,000kays and would run like a dream!
Good luck!
#17 _oikurtman_
Posted 11 September 2006 - 01:29 PM
i've done the ring around. looks like i'll be up for nearly $2000 to rebuild the 253. (doing it myself)
That's stage 1 cam, timing set, lifters, reco heads, pistons, rings, gaskets, seals, bearings and getting the carby rebuilt. Is it worth it?
Most internal work i've ever done to an engine itself is inlet manifold gaskets... I don't want to spend all that money and stuff it up!
drama, drama...
Posted 11 September 2006 - 02:34 PM
Assembly isnt TOO difficult if youve got the tools and a little bit of knowledge.. and some mates to help out who've hopefully done it before
You can definitely stuff it up assembling it yourself, but as i said above if you get some advise, a good manual, and the right tools then you should be ok!
Might it be worthwhile looking for an already rebuilt 253 or even 308 for the same kind of money?
#19 _Keithy's_UC_
Posted 11 September 2006 - 07:18 PM
I say GO FOR IT!!
Keith
#20 _oikurtman_
Posted 11 September 2006 - 07:56 PM
engine assembly guys tiny? i spoke to seperate blokes for cam, heads, carby and Repco for the rebuild kit. Know anyone worth a try in Sydney?
I'd like to try it myself, I have a manual, spanners, sockets and a torque wrench. But yeah, lot of money, lot of time, lot of risk.
Posted 11 September 2006 - 08:06 PM
But having read what you've said it looks like youve got the tools to do it, and enough knowledge to give it a go!
You'll DEFINITELY need to get the block bored.. there's no doubt about that. You'd be best off taking the engine in pieces to a workshop and getting the engine builder to do all the measuring, machining and even order the parts for you. Then you can take it back, and do the assembly yourself!
You'll need at the VERY LEAST things done like:
Bore and hone block
Possibly deck block so its flat and square
Deck heads so theyre flat and square.
These things need to be done by professional engine builders/machinists.
All in all there's alot of work in it, but honestly.. there's n othing more satisfying that kicking it over for the first time and being able to say " I did that!"
Good luck which ever way you go!
#22 _LHoon_
Posted 11 September 2006 - 09:02 PM
In my opinion, I think you'd be better off buy an honest second hand motor, either 253 or even 308 which is a good runner. It would only cost around $300-500 for a good motor, which you can drop straight in and it would be good for years.
#23 _oikurtman_
Posted 11 September 2006 - 10:06 PM
#24 _oikurtman_
Posted 11 September 2006 - 10:07 PM
#25 _Chamois hatch_
Posted 11 September 2006 - 10:23 PM
