308 Turbo pattern, obviously been decked and restamped.
There is an 'L' stamped near the date code also.
Any info appreciated.
Posted 07 February 2024 - 10:46 AM
Posted 07 February 2024 - 11:15 AM
SA Police number issued in 1987 :-)
Posted 07 February 2024 - 11:26 AM
The 115th Chassis or Engine number issued in 1987 by South Australian Police.
Is it a 1976 or 1986 block? 1986 will have 308 on both sides and it will have been a 304 originally, 1976 will be 308 on one side only. You'll also pick it by the length of the valley head bolt bosses.
Posted 07 February 2024 - 12:54 PM
Posted 07 February 2024 - 02:36 PM
People turn their nose up at Police issue number stamped blocks. They aren't a bad thing to have for what should be an obvious reason.
Posted 08 February 2024 - 09:25 AM
Is that piston 80 thou oversize? That would be stretching the limit in a Holden V8. Or has it been sleeved?
Posted 08 February 2024 - 11:12 AM
Gem used to sell them 80 over Laurie. I've seen plenty. I used to regularly buy HJ-HZ 5.0L Statesman, Premier etc as daily drivers back in the 90's. Whenever they had a Gem engine they often got hot. Not sure if it was the large pistons or if a misguided person used the wrong or no thermostat, or the radiators needed cleaning. I just used them until rego ran out and wrecked them. Never had problems with original engine cars though other than the cams were normally buggered, and just about every time they'd need a starter and a water pump. Back then exchange starters were $60 and water pumps were almost free.
Posted 08 February 2024 - 11:30 AM
Posted 09 February 2024 - 05:15 PM
Posted 09 February 2024 - 06:11 PM
Posted 09 February 2024 - 07:02 PM
Posted 09 February 2024 - 09:19 PM
Thanks Byron that's good info I'll pass on. Not real sure what his plans are, it's actually a friend of my brother who owns it. It's also got 2 cylinders too many for my liking!
Posted 10 February 2024 - 05:09 AM
