Haltech R3
13 replies to this topic
#1 SmacT
SmacT
  • 1,004 posts
  • Name:Sam
  • Car:LX 4dr 355, TKX, BW
Posted 25 June 2025 - 10:26 AM
I have got to wondering if I upgrade my Haltech Platinum GM Sport to an R3 with a new 355 I am building. Has anyone on here gone to the R3? The GM Sport is a great plug and play puter, but doesn't have the features of the R3 and I want to update the stock Commo wiring too, as it's getting old. Another option would be a Elite 2500, however they seem to be being phased out. I can get good coin for my GM Sport.
So, has anyone done it with a Holden 304/355/383? I have questions. :-)
Attached File  Screenshot 2025-06-25 at 10.21.14 am.png   1.24MB   6 downloads
#2 neglectedtorana
neglectedtorana
  • 1,055 posts
  • Name:Tom
  • Car:LX Torana Sunbird
Posted 25 June 2025 - 10:03 PM
Hi Sam,
I haven't tried one but have been browsing and it looks like there is a replacement for the Elite coming soon called an S2 or S3 I think.
Might be worth checking out.
Haltech have a bunch of good YouTube videos
#3 SmacT
SmacT
  • 1,004 posts
  • Name:Sam
Posted 26 June 2025 - 10:28 AM
Yes, the S3 looks okay, I guess I am figuring R3 in case I change set ups down the track. Good call though. Just wary of all the extras, such as sensors, connectors etc and I can't seem to find many Holden 355 examples. Looking in the wrong spot I suspect. Thanks Tom.
#4 greenhj
greenhj
  • 14 posts
  • Name:joe bloggs
  • Car:imaginary
Posted 26 June 2025 - 07:52 PM
I have an elite2500 that I'll use to run a fairly simple turbo 355 and T400 combo.
No help to you since I haven't finished it but the 2500 will do everything I need and still has Haltech support.
I'll be converting to 8x coils and likely DBW throttle as well.
I couldn't justify the extra for the Nexus but I'm sure that will bite me on the arse later.
#5 SmacT
SmacT
  • 1,004 posts
  • Name:Sam
Posted 27 June 2025 - 12:25 PM
Thanks GreenHJ, I am just thinking Nexus as I want to go a standalone engine harness (fans, EWP, fuel pump, etc all on one loom) and the Nexus makes that easier. The 2500 is still a great bit of kit. I don't like the feel of DBW throttle, but do want to consider 8x coils. Geeze it's a rabbit hole though.
#6 greenhj
greenhj
  • 14 posts
  • Name:joe bloggs
  • Car:imaginary
Posted 27 June 2025 - 05:55 PM
Since you're in sydney, get in touch with "Tuned by Dale" and talk to him.
He works closely with Haltech on development, can do full custom wiring looms to suit what you want and is a gun tuner as well.
8x coils is "easy", put a VT distributor in it, job done. No reason not to do it if the ECU is capable.
If you haven't done it already, download the NSP software and have a play.
#7 greenhj
greenhj
  • 14 posts
  • Name:joe bloggs
  • Car:imaginary
Posted 27 June 2025 - 06:02 PM
I've gone the other way and kept dirty old relay logic for my EWP, fuel pump, fans etc since its already in and working fine and I'm a luddite at the best of times.
#8 SmacT
SmacT
  • 1,004 posts
  • Name:Sam
Posted 27 June 2025 - 07:07 PM
Ah great, thanks for that, I will look him up. Just what I am after. Yeah, I have that all working on relay fusebox too, but want to simplify/refine it all. And then never do it again. Ha ha. Thanks again.
#9 rodomo
  • 18,059 posts
Posted 27 June 2025 - 08:58 PM
Too many wires...................too many colours...................my brain hurts just lookin at it.
#10 warrenm
warrenm
  • 2,130 posts
  • Car:1972 LJ Torana
Posted 27 June 2025 - 10:09 PM
points file, feeler gauge, lets go.
#11 76lxhatch
  • 7,220 posts
Posted 28 June 2025 - 07:18 AM
I'm pretty happy with the Link so far, running 8 coils, sequential injection and electronic throttle (feel is actually very good, you have full control over the opening and tweaking the pedal spring helps too). The individual coils solves this problem:
If you do go that way consider adding a crank trigger and just using the distributor for cam sync, makes another small improvement by eliminating the degree or two of additional movement. Holden gave us a nice spot to mount the sensor:
If the Haltech is anything like the Link you should be able to use just about any sensor type and tooth configuration.
#12 greenhj
greenhj
  • 14 posts
  • Name:joe bloggs
  • Car:imaginary
Posted 28 June 2025 - 08:04 AM
That is a nice setup.
#13 SmacT
SmacT
  • 1,004 posts
  • Name:Sam
Posted 28 June 2025 - 05:35 PM
Ha ha. I get you fellas, but for me the benefits of all dem wires far outweigh the negatives. I've had my time changing points and jetting carbs, but I enjoy the new way more.
#14 SmacT
SmacT
  • 1,004 posts
  • Name:Sam
Posted 28 June 2025 - 05:42 PM
Yeah nice set up mate. Will defo run a crank trigger and good call on the sensor mount. I base my dbw feel on the bikes I've ridden with that set up, and hated it. Things have probably improved in the few years since then, and cars aren't as sensitive to throttle feel as bikes so I should try again I guess. Good food for thought.
