Holley help needed
5 replies to this topic
#1 Muzza
Muzza
  • 31 posts
  • Name:Muzza
  • Car:LH Torana
Posted 14 July 2025 - 05:54 PM
Hi All
I have brought a 390 Holley
on stripping down I have found this
Main 60. Should be 51
Power valve blanked off should be 65
Secondary plain, however has been cut and fitted sideways, also has quick change cover
Pri Metering block 7204-7 should be 34R8909AS
the metering valve has me stumped as I can’t find specs, except it is a correct number
NO choke, it appears to have never had one based on special Holley blanking screws
thanks for advise
#2 rodomo
  • 18,055 posts
Posted 14 July 2025 - 09:38 PM
Sounds like a race application.
#3 yel327
  • 13,741 posts
Posted 15 July 2025 - 08:15 AM
Hi All
thanks for advise
I had one like that once, it came with a pair off a tunnel ram. If you get me the list number I have a big book on Holley list numbers
#4 Muzza
Muzza
  • 31 posts
  • Name:Muzza
  • Car:LH Torana
Posted 15 July 2025 - 10:09 AM
The list number is 8007, i have the Holley book, what I can’t find anywhere is metering block differences between
the 7204 and the factory one 34R8909AS, all other bits are easily converted back to factory
#5 claysummers
claysummers
  • 3,677 posts
  • Name:Clay
Posted 15 July 2025 - 10:44 AM
Vacuum secondary 390CFM. I have an as new one coming in the post. Also got a refurbished one on the bench. Don’t know much about them.
You’ve looked at this?
https://documents.ho...cal_listing.pdf
#6 yel327
  • 13,741 posts
Posted 15 July 2025 - 11:02 AM
I think all I have listings for are:
R80507
R80507-1
R80507-2
R80507-3
R6299-1
R6895
R8007
R80341
I'll have a better look in the old 1990's book I have to see if there is more info but the condensed one doesn't list the metering blocks. I did find this though, last post in the thread:
https://www.forabodi...estions.193633/
Edited by yel327, 15 July 2025 - 11:02 AM.
