Fuel pump drive pin
5 replies to this topic
#1 Muzza
Muzza
  • 31 posts
  • Name:Muzza
  • Car:LH Torana
Posted Yesterday, 09:52 AM
Hi all
just fitting the cam into my 253 Build, and the fuel pump drive pin doesn’t protrude into the fuel pump eccentric, has anybody ever come across this, BTW i have tried to remove the dowel and it ain’t moving
The drive pin protrudes .440” and its needs to be .700” to secure cam and fuel pump
#2 Muzza
Muzza
  • 31 posts
  • Name:Muzza
  • Car:LH Torana
Posted Yesterday, 10:06 AM
The pic show how far the pin sticks out vs how far it should stick out
#3 Rockoz
Rockoz
  • 4,060 posts
  • Name:Rob
Posted Today, 10:24 AM
From my poor memory, I thought the fuel pump eccentric was a cup type arrangement.
The flat part goes against the cam not the hollow.
Only need a few mm for it to locate.
Does this help at all?
Rob
#4 Muzza
Muzza
  • 31 posts
  • Name:Muzza
  • Car:LH Torana
Posted Today, 10:40 AM
Cam seller wasn’t very helpful, and offered a new dowel, the problem being removing the old one, so here is my fix
i cut 2mm off the cam location dowel leaving 9mm into gear, and made another pin from the old camshaft 7mm long, ( 3mm into fuel pump and 4mm purchase into cam, and made another pin mudguard washer to hold it in place
#5 Shiney005
  • 9,733 posts
Posted Today, 10:43 AM
Sprocket first, then the eccentric.
Attached File  Screenshot 2022-03-30 075605.png   720.27K   1 downloads
#6 Muzza
Muzza
  • 31 posts
  • Name:Muzza
  • Car:LH Torana
Posted Today, 11:04 AM
 Yes of course
Job is finshed
