I am running the same setup and had to ground off the unused mounting lug on the back of the compressor. As you adjust the belt the compressor raises and slightly rotates colckwise. It clears no issues but there isn't much there. I am also running HQ engine mounts which sit the engine a little lower but I think from memory also move the engine forward slightly. Hope this helps. Dale
I have removed the unused lug to give better clearance with heater hose, I have HQ mounts as well as Tiorana mounts that have been cut down 13mm
These guys do a low side bracket setup specifically for Torana:
https://www.autoware...ressor-mount-2/
I have looked at this, it won’t work for me, thanks for the suggestion, I’m happy with the way I’m going
