I have the engine in now and i used the lower engine mounts, even thing clears better, although the front stabiliser bar hits on drivers side extractor pipe ( Pacemakers)
So I will sell off the Torana mounts
Just plumbing all up including Air con
would love to post photos, just can’t seem to get them small enough, advise would would be good
There are other ways, but the easiest I found was using Facebook.
Create a post and change who sees it to only you.
Facebook automatically reduces the size of the image so that you can use it here.
I just then save that image back to my computer, then use it to post here.
I then delete the post from Facebook.
Takes all of 20 seconds to do.
Rob
