V8 Flywheel bolt spacing
12 replies to this topic
#1 Muzza
Muzza
  • 83 posts
  • Name:Muzza
  • Car:LH Torana
Posted 20 August 2025 - 11:26 AM
Hi All
Ive just gone to fit my flywheel and it doesn’t fit
The bolt spacing on the crank is very close to 90mm
where as the flywheel that was provided with the engine has a spacing of 77mm
I have a flew plate  that is also 90
im thinking I don’t have a Holden fylwheel
 Can someone confirm
#2 UCSLE
UCSLE
  • 736 posts
  • Name:troy
  • Car:Goggomobil
Posted 20 August 2025 - 12:03 PM
77mm is about Holden 6 cyl size and would be a smaller overall diameter
Also If i remember right the holden v8 flywheel has 2 different bolt patterns for the pressure plate so check that when looking for another flywheel
Edited by UCSLE, 20 August 2025 - 12:04 PM.
#3 Muzza
Muzza
  • 83 posts
  • Name:Muzza
  • Car:LH Torana
Posted 20 August 2025 - 01:02 PM
looking at this further it appears i may havre V6 VN flywhel 77mm spacing with 6 pressure plates holes
My pressure plate has 6 even spaced holes, the kit i brought was for a253/308, so just need to but a 253/308 flywheel with even spaced pressure plates holes
Edited by Muzza, 20 August 2025 - 01:08 PM.
#4 rodomo
  • 18,068 posts
Posted 20 August 2025 - 09:13 PM
Dunno about your problem but Holden 6 bolt holes aren't evenly spaced. You have to rotate the f/wheel on the crank till the bolts line up.
#5 claysummers
claysummers
  • 3,726 posts
  • Name:Clay
Posted 22 August 2025 - 05:48 PM
and blue and black ones have different clutch bolt hole pcd to red.
#6 Muzza
Muzza
  • 83 posts
  • Name:Muzza
  • Car:LH Torana
Posted 22 August 2025 - 06:36 PM
 Are you referring to 6cyl or V8
 My question was on V8 PCD, which I believe is 90mm , and as mentioned my flywheel has a 6 cyl pattern with a v8 OD, I think it could be v6 commodore
#7 claysummers
claysummers
  • 3,726 posts
  • Name:Clay
Posted 22 August 2025 - 07:55 PM
Referring to 6cyl and clutch attachment, not crank.
#8 rodomo
  • 18,068 posts
Posted 22 August 2025 - 09:24 PM
#9 claysummers
claysummers
  • 3,726 posts
  • Name:Clay
Posted 23 August 2025 - 09:30 AM
That’s what I’m talking about Rob
#10 Shiney005
  • 9,861 posts
Posted 24 August 2025 - 12:42 PM
There are two types of V6 flywheel. Only the early series 1 VN had six crank bolt holes. All others from then on had eight. This one is the later dual mass jobbie, but the earlier one looks very similar.
Attached File  Flywheel dual mass VT-VY.png   1.61MB   4 downloads
The Holden V8 one looks quite different.
Attached File  Flywheel V8 b.png   1022.38K   5 downloads
Attached File  Flywheel V8 c.png   1.16MB   4 downloads
#11 Shiney005
  • 9,861 posts
Posted 24 August 2025 - 12:46 PM
The other one you may have is VL 6 cyl which has six holes and looks more like the V8 one.
#12 Muzza
Muzza
  • 83 posts
  • Name:Muzza
  • Car:LH Torana
Posted 24 August 2025 - 04:58 PM
This the one I have, that I can’t ID as yet, I have ordered a new v8 from flee bay
#13 Shiney005
  • 9,861 posts
Posted 24 August 2025 - 06:48 PM
Got me stuffed. Maybe it is a Yella Terra six cyl one drilled to accommodate a V8 pressure plate. Either way, it looks like you are buying another one.
