Wheel wobble
17 replies to this topic
#1 TORLX8
TORLX8
  • 586 posts
  • Name:Campbell
Posted 14 September 2006 - 11:34 PM
After being told by guys following me I had a wobble in my left rear wheel, I jacked the car up and put it on axle stands and put it in gear to check it out.
Sure enough that wheel had quite a wobble. These wheels are quite new, so in shock I took the wheel down to the local tyre place and had them put it on the balancer to check it out. A relief that the wheel was ok, but thinking that must mean I have a bent axle. The diff was gonna get reconditioned anyway, so I took the whole lot in to the diff place, and sure enough they had to straighten that axle.
Now I thought everything would be good, but after reinstalling the diff, I put it in gear on the axle stands again, and the wobble was still there. :cry: I knew it wasnt the wheel, so took the axle out again to take back in and have rechecked. Its fine they say. Maybe a brake drum? So ran the car on axle stands again with the wheel off and the brake drum reversed. Yep, a definite wobble there. So guessing I had a warped drum went and purchased another from the local wreckers. Got home and tried the same test, but that one wobbled too.
At this stage I called the diff place again to see if they had any suggestions, and they suggested maybe the drum wasnt seating properly and to file the centre out a bit. Tried that with no luck.
Im really stumped as to what else it could be.
Any ideas anyone?
#2 _RCK-914_
_RCK-914_
Posted 14 September 2006 - 11:58 PM
have you tried putting 1 of your other wheels on to see if it still does it ? the only other think that I can think would be rear bearings.
Cheers Chris
#3 TORLX8
TORLX8
  • 586 posts
  • Name:Campbell
Posted 15 September 2006 - 12:12 AM
yep tried that too, and new bearings were put on, so buggered if I know...weird
#4 rodomo
  • 18,051 posts
Posted 15 September 2006 - 12:28 AM
Try the other axle in your problem side, but don't drive it! Axles don't like direction change under load. They snap! If the wobble stops it's the axle. If it doesn't maybe the housing is bent or the spigot for that axle gear is worn in the diff centre?
Edited by rodomo, 15 September 2006 - 12:32 AM.
#5 TORLX8
TORLX8
  • 586 posts
  • Name:Campbell
Posted 15 September 2006 - 01:01 AM
Its a 9inch, so axles are different lengths. Whole housing has been checked for straightness, and diff has been reconditioned.
Like you're thinking though, thanks for the suggestions.
#6 rodomo
  • 18,051 posts
Posted 15 September 2006 - 01:06 AM
Im still thinking bent axle. Try another rim? Balance may be o.k. but rim may be bent?
#7 TORLX8
TORLX8
  • 586 posts
  • Name:Campbell
Posted 15 September 2006 - 01:21 AM
I know its not the wheel, that was the 1st thing I checked. Took it to the tyre place and put it on the balancer. Perfect.
I reckon its either gotta be axle or brake drum. Drum wobbles without the wheel on.
Another suggestion I just had from Greenmachine was to bolt up wheel without brake drum. Will try that one tomorrow.
cheers.
#8 _HB1200_
_HB1200_
Posted 15 September 2006 - 06:41 AM
Do your rims have cbl rings in the bores? It is bossible that it may not be seated properly. This may not be evident at the tyre shop due to the mounting of the wheel.
HB1200
Edited by HB1200, 15 September 2006 - 06:43 AM.
#9 GML-31
Posted 15 September 2006 - 07:09 AM
I take it all your control arm bushes are OK?? if they are worn they will make a small wobble look 10 times worse.
#10 _timbotorrie_
_timbotorrie_
Posted 15 September 2006 - 08:28 AM
what about the axle flange? where the studs are pressed in, is that running true? it only needs to be a bees d&^k out to make a difference
#11 TORLX8
TORLX8
  • 586 posts
  • Name:Campbell
Posted 15 September 2006 - 11:10 AM
Control arms and bushes are all brand new.
No, wheels dont have rings in the bores.
Axle flange may be something else to look at.
I'm sure we'll eventually nail this...Thanks
#12 TORLX8
TORLX8
  • 586 posts
  • Name:Campbell
Posted 15 September 2006 - 11:55 AM
Just bolted up the wheel without the brake drum on and its perfect.
Somethings wrong with the brake drum by the looks, but I also tried another brake drum and same thing happens????
#13 _Aidan_
_Aidan_
Posted 15 September 2006 - 05:38 PM
maybe you got unlucky on the 2nd hand purchase?
#14 rodomo
  • 18,051 posts
Posted 16 September 2006 - 01:07 AM
Maybe the drum is distorting as you pull up the nuts. Make sure your drums are identical. Swap drums to the problem side and see if this fixes it. I think I read somewhere that Holden rear drums differ from model to model e.g HK/T/G and Torry where they can have a different dish?
Intrigued now,
Good Luck!
#15 _82911_
_82911_
Posted 16 September 2006 - 06:14 PM
Try this...........
take your brake drum off and have a look atte axle flange......Is the knurled part of the wheels stud protruding through the axle flange face? If so that could be the problem....
To fix......open up your stud holes in the brake drum slightly with a die grinder.. you don't need to worry about the change in PCD of the drum as the drum spigots off the centre of the axle so all will remain centred.
Cheers Greg..
#16 TORLX8
TORLX8
  • 586 posts
  • Name:Campbell
Posted 17 September 2006 - 10:45 PM
These are all great possible solutions to the problem. Thanks all.
I got pissed off with it all yesterday, and booked it in to a brake place and just put it all back together. Thought I'd just check it in drive on the axle stands again. To my shock :o the wobble had gone. This had me really intrigued, why had it suddenly gone away? I went to the brake place anyway so everything could be checked and properly adjusted up and told him what had happened. He reckons I just may not have lined up the dimple in the brake drum with the hole in the axle.
OMG I was so pissed off with myself, how could I miss something so simple.
Quite embarrassing really. :fool: :banghead:
Guaranteed i won't make that mistake again.
#17 _timbotorrie_
_timbotorrie_
Posted 19 September 2006 - 08:19 AM
:clap: :tease:
#18 _devilsadvocate_
_devilsadvocate_
Posted 19 September 2006 - 04:11 PM
Glad youve got it sorted, ........ it was interesting to read all the other possible causes which all offer good background knowledge for further problem solving.
