measuring PCD
13 replies to this topic
#1 _nibbsy_
_nibbsy_
Posted 18 September 2006 - 11:02 PM
I have just picked up a set of steel rims for my LH that runs HQ pattern while i save up and buy a decent set of wheels.
They are 15" in diameter and i think they might be commodore pattern cos they came with hub caps that look they are off a VR and i'm pretty sure HQ would have never had a set of 15" back in the day.
I was after a way to measure the PCD accurately and check out if they are commo or HQ.
Could someone also tell me which one is which, 120.5 is HQ or commo and if 120.9 is commo or HQ.
Thanks heaps
nibbsy
#2 warrenm
warrenm
  • 2,123 posts
  • Car:1972 LJ Torana
Posted 19 September 2006 - 08:19 AM
Commodore is 120mm
HQ/WB is 4 3/4" (120.8mm")
#3 makka
makka
    A m��se once bit my sister
  • 3,559 posts
  • Name:Cohen
Posted 19 September 2006 - 12:40 PM
Commodore is 120mm
HQ/Chev is actually 120.65mm or 4 3/4"
#4 _devilsadvocate_
_devilsadvocate_
Posted 19 September 2006 - 01:07 PM
To answer your question.........any easy way to measure pcd is to measure the distance between the centre of adjacent studs.
Finding the centre of the wheel or measuring to it is not always easy.
Using some basic year 9 trigonometry:
The pcd of the wheel in inches will be (dist bw studs in cm/ 1.49)
pcd(in)= adj studs (cm)/1.49 (for five studs)
or dist bw studs (cm) = 1.49 x pcd
For a torrie wheel 4.25in(or is it 4.24) pcd, dist bw studs = 1.49 x 4.25 = 6.35cm
Hope this is of help
Edited by devilsadvocate, 19 September 2006 - 01:17 PM.
#5 _HB1200_
_HB1200_
Posted 19 September 2006 - 04:12 PM
Ring around your local tyre/rim stores, they some times have a gauge that measures the distance between adjacent studs and shows the pcd on a sliding scale.
HB1200
#6 _nibbsy_
_nibbsy_
Posted 19 September 2006 - 10:58 PM
I'm flat out remembering year 9 let alone trigonometry from it!!! :tease:
Thanks for the replies guys, i was thinking of just taking one down to a tyre shop and seeing if they can suss it out for me.
Cheers again
nibbsy
#7 _devilsadvocate_
_devilsadvocate_
Posted 20 September 2006 - 12:10 AM
Thats why I gave you the formula for pcd from stud separation, I only mentioned it being yr9 maths(which it is) as there would be those on this forum that would waste time challenging that it was plucked out of thin air etc
Anyway understand the prob, you have a rim with the holes for the studs and you have to be able to measure to near to an accuracy of 0.7mm and have difficulty actually deciding exactly on the centre of the holes.
One way to do this with the holes is measure the distance of the closest edge of one hole to the closest edge of the an adjacent hole and measure the distance of the furthest edge to an adjacent furthest edge, add the two together and divide by 2.
Id be confident of a correct answer using a mm ruler, but would be best done with a vernier.
Id imagine that a tyre shop perhaps might have something to help out.
#8 makka
makka
  • 3,559 posts
  • Name:Cohen
Posted 20 September 2006 - 12:17 AM
or you could save yourself time by measuring to the closest side of 1 hole, and the furtherest side of the other........
#9 _devilsadvocate_
_devilsadvocate_
Posted 20 September 2006 - 12:34 AM
Came back to edit , but Makka has beaten me to it. :D
#10 makka
makka
  • 3,559 posts
  • Name:Cohen
Posted 20 September 2006 - 12:39 AM
the quick and the dead round here!
looks like your the latter this time :tease:
#11 _devilsadvocate_
_devilsadvocate_
Posted 20 September 2006 - 01:02 AM
hmm ^ in this context wouldnt it be the "quick OR the dead" :nada: ...........either can make sense I suppose..............the original saying came from those who lived to hard and died early.
Edited by devilsadvocate, 20 September 2006 - 01:09 AM.
#12 makka
makka
  • 3,559 posts
  • Name:Cohen
Posted 20 September 2006 - 01:08 AM
yes i suppose it could be, now im the latter :banghead: :shoot:
I suppose it depends on how much you want to debate it......
Edited by makka, 20 September 2006 - 01:09 AM.
#13 _devilsadvocate_
_devilsadvocate_
Posted 20 September 2006 - 07:46 AM
Hell no...........be a good essay discussion topic for some of our readers still at school though.
Edited by devilsadvocate, 20 September 2006 - 07:47 AM.
#14 warrenm
warrenm
  • 2,123 posts
Posted 20 September 2006 - 08:44 AM
Makka you are correct,I was in a hurry & never checked it before I typed it.Check out this site http://www.romac.com... Calculater.pdf
