Torana fuel gauge sender to commodore pickup
10 replies to this topic
#1 _Keithy's_UC_
_Keithy's_UC_
Posted 19 September 2006 - 04:07 PM
Hey guys,
I've got a VN V8 fuel pump/pickup in the drop tank and my standard UC wiring going down there. I need to run a fuel gauge for obvious reasons, but i cant because 1) they dont connect and 2-) the ohms required for commodore may be different to UC Torana and therefore give me an inaccurate reading.
Has anyone fitted a commodore V8 pump and pickup to their tank before, and if so, what dramas did you come across and how did you overcome these?
Any info appreciated as i would like the tank in asap.
Keith
#2 _devilsadvocate_
_devilsadvocate_
Posted 19 September 2006 - 04:33 PM
This link is useful for finding the resistance ranges of various senders for different models and makes: http://www.apamfg.co.....rt Poster.pdf
It lists the vn specs as the same for the uc, so it its not going to fry your uc gauge, but whether you get linear readings etc......dont know.
#3 _Keithy's_UC_
_Keithy's_UC_
Posted 20 September 2006 - 10:10 AM
Ok, so by going off that chart, the comodores (VN - VS) have the same sender for an LPG tank and obviously it'll have the same ohm range with a standard petrol tank as they wouldnt fit something they would then have to modify... I'd like to know more. If it's just a case of putting an adaptor to the sender from the tank to mate up with the UC fuel gauge sender, it's a pretty much plug and play issue...
And if thats the case, then my drop tank could be going in sooner than expected...
Cheers for that devils..
Keith
#4 Dr Terry
Dr Terry
  • 3,341 posts
Posted 20 September 2006 - 10:48 AM
Hi Guys.
The UC Torana fuel sender has the same specs as VB to VS Commodore.
That is - 282 Ohms Empty, 97 Ohms Half & 40 Ohms Full.
You're in luck Keith, what that means, simply translated, is any fuel or LPG sender that runs a VB to VS fuel gauge will work perfectly with your UC Torana gauge.
Dr Terry.
#5 makka
makka
    A m��se once bit my sister
  • 3,559 posts
  • Name:Cohen
Posted 20 September 2006 - 12:15 PM
are UC the same as LH/X aswell?
#6 _devilsadvocate_
_devilsadvocate_
Posted 20 September 2006 - 01:21 PM
No, 73-10 Ohms for LX/H
#7 _Keithy's_UC_
_Keithy's_UC_
Posted 20 September 2006 - 01:46 PM
Dr Terry and Devilsadvocate - you guys are legends... may have saved the day!!
Keith
#8 Dr Terry
Dr Terry
  • 3,341 posts
Posted 20 September 2006 - 01:54 PM
Hi makka.
No, the LH/LX senders are 73 ohms empty, 25 ohms half & 10 ohms full, same as late HQ, HJ/HX/HZ & also WB (commercials).
Dr Terry.
#9 _Keithy's_UC_
_Keithy's_UC_
Posted 20 September 2006 - 02:15 PM
Next question... Does anyone know somewhere that sells adaptors from the commodore sender to mate up with the torana plug?
Keith
#10 _UCV80_
_UCV80_
Posted 20 September 2006 - 04:29 PM
Yay! will the tank go in b4 your holiday?? i hope so, would look tuff as :spoton:
#11 _Keithy's_UC_
_Keithy's_UC_
Posted 20 September 2006 - 04:48 PM
Fingers really crossed and double crossed...
