VN V8 Head stud problem
#1 _LHoon_
Posted 21 September 2006 - 08:41 PM
See the picture below (the right nut is the problem one)
So what's my best option? Do I remove that stud and just put a standard bolt back in? Or should I try grinding a bit of clearance around this nut?? Why is this particular head bolt different to the others? Has anyone else come across this problem?
#2 _rorym_
Posted 21 September 2006 - 08:45 PM
Posted 21 September 2006 - 08:51 PM
#4 _LHoon_
Posted 21 September 2006 - 09:00 PM
Is there any reason why I can't 'create' some clearance? I mean, I may as well use those two head studs - considering I've paid for them and they're meant to be better and all....
Why is this particular bolt arranged like this, anyone know?
Posted 21 September 2006 - 10:17 PM
Edited by rodomo, 21 September 2006 - 10:18 PM.
#6 _82911_
Posted 21 September 2006 - 10:27 PM
Keep in mind though that you might still run into interferance problems with your extractors fouling on the studs..
CHECK EVERYTHING... if you choose this option.
Or put the factory capscrews in those 2 spots and clamp it all down.... Go have a beer...
Much simpler idea really........
Cheers Greg..
#7 _LHoon_
Posted 21 September 2006 - 10:33 PM
Hmmm.... I don't know, I haven't actually got extractors yet!! Maybe that's why I will actually need to use the bolt instead of the stud. Good point!!Can you fit your exhaust with those studs? Looks a bit close in the pics?
Here's a slightly different angle:
#8 _LJ355_
Posted 21 September 2006 - 11:25 PM
#9 _bodallafella_
Posted 21 September 2006 - 11:45 PM
Posted 22 September 2006 - 08:41 AM
#11 _LHoon_
Posted 22 September 2006 - 05:04 PM
Posted 22 September 2006 - 08:00 PM
Posted 23 September 2006 - 08:25 PM
Dave
#14 _gtr-xu1_
Posted 24 September 2006 - 01:20 AM
#15 _CHOPPER_
Posted 25 September 2006 - 02:34 AM
#16 _[BOTTLEDUP]_
Posted 26 September 2006 - 09:30 PM
Posted 27 September 2006 - 08:59 AM
Without opening up the old can of worms, I'd like to hear some of you guy's thoughts on a problem I've had with head stud kits. I've used them on several engines, mainly blown or nitrous V8s & have found that if you use the same torque figures as factory bolts they distort the deck & overcompress the gasket material. What I have found is that because the nut thread is UNF, which is a finer pitch than the UNC thread into the block, the same torque figure causes a much higher bolt 'tension'. In other words the bolt (or stud) is 'pulled' more because the pitch is finer.
It took me a while to find any info on this, but there are some engineering standards that allow the difference to a factor of 1.5. In other words a UNF bolt torqued to a 100 Nm will result in the same actual bolt tension as 150 Nm for a thread of the same diameter but with a UNC thread.
Anybody else had experience in this area. Many people don't even think of this & torque the studs to the factory UNC bolt specs.
Dr Terry.
#18 _LHoon_
Posted 27 September 2006 - 02:22 PM
However, I just followed the torque specs that came with the ARP head stud kit, rather than using the Holden specs that came with the head gasket.
Posted 27 September 2006 - 04:04 PM
What torque figures did ARP give. Much less than factory ??
Dr Terry.
#20 _LHoon_
Posted 27 September 2006 - 04:17 PM
Standby...
#21 _82911_
Posted 27 September 2006 - 05:08 PM
BUT....
I can't see the factor really being a straight 1.5:1
maybee there is a sliding scale??
Reason I say that is I can't imagine that the head on my 12;1 comp 202 is going to stay put for very long with only 42.5ft/lb on the studs!
I would be very keen to know what the end results of this search is........
Cheers Greg..
#22 _bodallafella_
Posted 27 September 2006 - 07:30 PM
7/16 Stud = 71 ft/lbs
7/16-UNC = 73 ft/lbs
7/16-UNF = 80 ft/lbs
So it seems that the difference between a UNC and UNF bolt is greater than between a bolt and a stud but still nowhere near 1.5 times. This assumes that ARP have correctly compensated for this effect which they may not have. If you look at the tech info in the ARP catalogue you will see that they really know their shit and I doubt they would overlook something as basic as thread pitch. I have used ARP head studs on a number of high powered Holden strokers as well many other engines and have never noticed this problem but I always follow the recommended torque specs and use the ARP lube.
Nick
#23 _LHoon_
Posted 27 September 2006 - 09:47 PM
So I used 85 ft lbs because I only had motor oil available as a lubricant at the time (and not the ARP assembly lube). I'm not sure what standard Holden specs are. So, by how much do they differ?Torque values are based on 75% of the fasteners yield strength.� Use the manufacturers torque sequence but do not use the engine manufacturers torqu specs.� Torque nuts to 70 ft lbs for ARP MOLY ASSEMBLY LUBRICANT or torque to 85 ft lbs with 30wt motor oil.
Edited by LHoon, 27 September 2006 - 09:48 PM.
#24 _LX406_
Posted 27 September 2006 - 10:05 PM
#25 _bodallafella_
Posted 27 September 2006 - 10:48 PM
