OK..Next..Chev 307/350 Vs 308 weight?
20 replies to this topic
#1 _rorym_
Posted 25 September 2006 - 08:06 PM
More info needed...Also whats involved in fitting the chev in an LH?..From a cost point of view there is sheet loads of cheap performance parts for Chevs and you can get them humming pretty cheaply.
#2 _MRNOS_
_MRNOS_
Posted 25 September 2006 - 08:09 PM
Chev is a better fit than a 308, more room between heads and chassis rail, pretty easy fit up, sump extractors, radiator, engine mounts
Edited by MRNOS, 25 September 2006 - 08:10 PM.
#3 dattoman
Posted 25 September 2006 - 08:10 PM
I'll let you know once I'm finished (started)
#4 _MRNOS_
_MRNOS_
Posted 25 September 2006 - 08:12 PM
Ring me if you need more info Rory, had 3 chev powered toranas, easy conversion
#5 _rorym_
Posted 25 September 2006 - 08:16 PM
Find me a weight comparison...then we might just change the game..easier to get the HP I want from a Chev. Then I can rerally light them up like Croads orange HQ Monaro at Targa! :spoton:
Edited by rorym, 25 September 2006 - 08:17 PM.
#6 _MRNOS_
_MRNOS_
Posted 25 September 2006 - 08:27 PM
Rory about 530pounds for a 400 chev bottomend minus heads
#7 LS1LX
LS1LX
  • 1,931 posts
Posted 25 September 2006 - 08:38 PM
The weight is about the same between a SBC and a Holden V8.
These days though it comes down to what your bolting on, SBC you can get alloy heads cheap, alloy heads for Holden V8's aren't exactly cheap when you compare.
But lighten the thing up with alloy manifold, mini starter, alternator and alloy water pump, you dont need any other accessories, no P/S or A/C and you've got a light enough V8.
There's heaps more thing you can do to lighten a SBC and it will always be cheaper and make more HP per $ then a Holden V8.
You have the same choice of transmissions between the 2 engines, assuming the holden is turbo pattern if not you could always run a mighty trimatic or super strong aussie 4 speed behind that 308.
Go the SBC you won't regret it, you'll never build a 308 again though. Once you go with the chev's you generally for some dumb reason just get hooked, I think its the name.
#8 _rorym_
Ebay is showing a 350 long motor no acces..alt etc at 400 lbs.
Clearence OK on the steering?
#9 Racehatch
Racehatch
  • 1,028 posts
Posted 25 September 2006 - 11:42 PM
Prob the only thing you have to watch out for is extractors, a few blokes on here have had a few issues with clearance near the steering knuckles and also the sump (if its a hi energy style).
I spent the cash and got a custom made setup, that can be dismantled, well worth the money, esp if u need to do a clutch or gearbox...
#10 355LX
355LX
    Long Term Project
  • 611 posts
  • Car:LX hatch
Posted 26 September 2006 - 01:26 AM
The old 253/308 was based on the chev originally for some of it's inspiration, one of the goals i think was lighter weight. I think it was about 20kg's lighter than the chev, or was it 40kg, I can't remember.......I think 20kg's.
Dave
#11 TerrA LX
Posted 26 September 2006 - 01:53 AM
it is actually based on a buick, and depends if you talking old or new for weight as a red 308 is easy 20kg lighter than an equivilant chev (with cast iron water pump etc) but an alloy head later chev will be lighter than a VN headed 308.
#12 _keith1962_
_keith1962_
Posted 26 September 2006 - 06:15 AM
Hi Rory
Are you worried about the weight of a engine?
I would be thinking of more power inwhich i would
have 308 over a 350 only because i have seen a lot
of stroked 350's being flogged by stroked 308's.
cheers Keith
#13 _MRNOS_
_MRNOS_
Posted 26 September 2006 - 07:59 AM
Rory a nice 350/383 chev with a set of alloys-dart or world products- will make the sort of power you want-with ease- Tremec 5spd, B/W diff, what a weapon!
#14 _rorym_
Posted 26 September 2006 - 02:36 PM
D,
You and i will have to go through specs on pistons, comp ratio,cam specs, heads etc to see what I need to get 400+HP, 2 or 4 bolt main block? 2 or 1 piece rear main seal? etc etc
780 DP? The Chev stuff is WAY cheaper to get and so is the engine. Plenty of 350/400 4 bolt long motors from $450 to $1100...trouble is they are all in Vic!
Edited by rorym, 26 September 2006 - 02:37 PM.
#15 _MRNOS_
_MRNOS_
Posted 26 September 2006 - 02:49 PM
Plenty on offer down my way mate! :spoton:, and brand new 350 Blocks start at $1500ish maybe a bit cheaper
Edited by MRNOS, 26 September 2006 - 02:55 PM.
#16 makka
makka
    A m��se once bit my sister
  • 3,559 posts
  • Name:Cohen
Posted 27 September 2006 - 09:45 AM
of its going in a circuit car, why not go a 302? you want something that revs!
#17 bryanw
bryanw
  • 294 posts
Posted 28 September 2006 - 01:51 PM
just put the ls1 in it.
streetmachine has 325 hp at the wheels on their project car, has tune, extractors, otrcai, mafless, baby cam, new valve springs as it is a 160k plus engine.
thats with the power sapping auto.
would be interesting to see the results with the 300kw intake manifold, 90mm intake, std is 75mm.
this engine in a full weight LH would be in the low 11 sec, if not high 10's with a little diet and traction.
and behave like a stock engine! economy not bad either on pump fuel
this is still a std motor with bolt on's and cam.
complete ls1 motor/auto/computer etc sell for less than what you would spend on your chev/holden to get similar power, and sm are not finished.
maybe just buy a complete write-off with manual trans.
sell off what you don't want
then there is the 6spd.
am thinking of the same in a lc/j. rather than stuff a 308 in the gtr.
possibly low 10's without pulling the heads off!
or a 150hp shot of gas in a dry system, keep the maf. would have to be the cheapest 9sec car you could build.
or you could just stick with the old heavy chev, they do sound better.
#18 _rorym_
Posted 28 September 2006 - 03:22 PM
350 Chev 4 bolt (purchased)
Alloy Heads
Barry Grant carb
Cam to suit
383 crank
H Beams
Flat tops
Edelbrock
Roller rockers.
460 HP
Under 2 grand.
Easy!
Second hand LS1 is $5000
Edited by rorym, 28 September 2006 - 03:23 PM.
#19 _MRNOS_
_MRNOS_
Posted 28 September 2006 - 03:24 PM
Hmm we'll see who's cars quicker :driving:
#20 bryanw
bryanw
  • 294 posts
Posted 29 September 2006 - 09:48 AM
rory will have finished his before I have decided on a colour!
may not be the quickest in unopened configuration, but sure to be the most drivable.
ls1's have got cheap, try ebay, last week one didn't get a bid at $2000, low kays, auto, comp and all accesories. complete damaged cars are under 5k.
easy sell off 2-3k in parts, if not more.
then you might look for an ls6, as holden fitted lots of those as they ran out of ls1's for a while.
was just giving other options since you were asking about weight.
hope the chev works out well
#21 _rorym_
Posted 29 September 2006 - 01:28 PM
Bryan..no dramas..wasnt razzing you...I just dont want the drama of the electronics and stuff...plus I can lighten the Chev with alloy heads,waterpump,etc etc..I will need SOME weight over the front wheels! :D
