My bro' in law has an overheating LH 253. He's put a 4 core rad and it's perfect5 but the thing is suffering in the heat.
Anyone fitted a rad shroud form another holden in an LH - HJ-Z maybe or Commodoore???
Radiator fan shroud
_stevet_
, Nov 10 2005 04:01 PM
7 replies to this topic
_stevet_
Posted 10 November 2005 - 04:01 PM
Posted 10 November 2005 - 04:57 PM
A 4 core? I doubt a shroud is gunna help that much...I'd be looking at the motor itself.
Dodgy thermostat, wrong temp thermostat, perhaps the radiator cap isn't holding pressure?
_workinprogress_
Posted 10 November 2005 - 05:06 PM
There is a dozen things that could cause overheating. and with a 4 core radiator i doubr your problem is anywhere in that area. There could be a reastriction in the flow of the water around the engine somewhere (i would have a look at the heater maybe?). otherwise poor ignition or valve timing could do it. is the exhaust in good nick?
_workinprogress_
Posted 10 November 2005 - 05:09 PM
check out the "cooling system now working" thread in the engine forum posted by lxss. looks like it could help you. he had an overheating 253 and fixed the problem. he could probably help you out with anything you needed
_Yella SLuR_
Posted 10 November 2005 - 09:09 PM
Also check that you still have a spring in your lower rad hose to make sure it isn't collapsing in on itself!! Mine didn't have one in it when I bought it, and it liked to belch water.
Edited by Yella SLuR, 10 November 2005 - 09:09 PM.
_stevet_
Posted 14 November 2005 - 08:31 AM
Cheers guys. I've passed all your tips on to him and we'll have a go.
Thanks.
Thanks.
_JBM_
Posted 18 November 2005 - 04:29 PM
There is a radiator shroud listed on the Rare Spares website, its fibreglass and description says "A9X type".
The HQ-HZ plastic type hits the fan, probably because of a height difference between the radiator and the engine.
_lxss_
Posted 25 November 2005 - 12:34 AM
Any more details on the overheating? When driving hard? Revving high? Normal Cruising? Is it leaking any coolant? What is the coolant/water mix? The more details you give the more things you can rule out. Hope it all goes well though. I know how annoying a hot (overheating) 253 can be. Has it been bored out by any chance?
