looking for a new water pump for 308
Posted 03 October 2006 - 03:27 PM
im looking for a water pump that would flow better then a standard pump as im having over heating problems. i bought a standard pump from rsp think it was the power max one.
can anyone recommend one thats better than a standard one???
its for a holden 355 and id prefer not to use an electronic pump.
danny...
#2 _LHoon_
Posted 03 October 2006 - 03:52 PM
I don't think you can really get any better ones, other than the electric pumps of course.
Posted 03 October 2006 - 05:01 PM
if you are running the cast impeller type and there is not too much clearence between the impeller and body, and the water is flowing thru the system, then look else were for your overheating probs.
is it overheating, loosing water, or just running over temp, say over 110 deg C.
#4 _1QUICK LJ_
Posted 03 October 2006 - 11:13 PM
Posted 03 October 2006 - 11:41 PM
#6 _big chris_
Posted 04 October 2006 - 03:53 PM
I would look at the flow thru on your radiator first,
we replaced the waterpump, thermostat, and housing etc,
then last, should have done first, new radiator.
problems solved, dodgy flow thru, looked like it was working,
but was not fully flowing.
Chris.
#7 _devilsadvocate_
Posted 04 October 2006 - 05:17 PM
One basic test is to accurately measure the temp of the water going in and out of the radiator. Infrared temp sensors are great for this, you can buy cheap ones that work for ~$40-50, or perhaps visit a radiator shop where they should be able to do the test for you.
Its best to test when the temp in the engine has got above thermostat temp so you can be sure the thermostat is not retarding flow.
If you see a large temp difference across the radiator at any rpm , larger than 10C, this would indicate that the coolant is not circulating fast enough...........its going to vary a little depending on the rpm whether you have an engine fan(one that puts more air through as the pump spins faster) or electric fan. Hopefully the guys at the radiator place will have some experience in what would be good differences to see with your setup. Certainly if the bottom hose feels colder to touch when the motor is supposedly very hot, then you have a circulation problem.........which may be the water pump...........could be blockage elsewhere.
A basic test for radiator flow: fill rad......dont fit cap........remove bottom hose.......time how long it takes to empty.........more than 2 secs......get it looked at.
Edited by devilsadvocate, 04 October 2006 - 05:20 PM.
Posted 04 October 2006 - 06:59 PM
The top rad hose is alot hotter than the lower hose just by feeling it and i have
measured the tep with a infrared thermometer and its more then 10c difference to the lower hose.
I also have flushed the motor out and the radiator too. Thermostat is working fine.
Its a reco hq 4core radiator.
Could a leak from somwhere cos overheating as well??
Like a head gasket??
Danny..
#9 _devilsadvocate_
Posted 04 October 2006 - 07:40 PM
If you can noticeably feel the difference by hand between top and bottom hoses (with the essential proviso that the coolant temp has risen well above the thermostat temp) then you have a major circulation problem. Of course if the coolant temp in the engine is being maintained at thermostat temp by the restricting action of the thermostat then there could be substantial differences from top to bottom hose
Edited by devilsadvocate, 04 October 2006 - 07:42 PM.
Posted 04 October 2006 - 07:51 PM
have the system pressure tested.
#11 _Lostit_
Posted 04 October 2006 - 08:35 PM
Are you actually losing any water ... since the water in the motor is a enclosed system ... your water level should never change .If you arent losing water , next step.
Are you 100% sure you r thermoset is working properly ? 180 Deg ?
Are you running coolant ? if so how old is it ? since coolant actually goes slimy when it ages its bad .
If you can answer to all above questions that all are working ... and the water pump isnt leaking water making grinding noises( bearing failure) then actually i would be looking at your radiator... i know its a 4 core , but maybe its not big enough 5 core are available... or aluminium ones( costly thou ).
To give a idea i run a 400 with a standard water pump but custom aluminium radiator with AU twin electric fans .. and on a cool night i can drive literally 30kms before i need to turn them on and only for like 1-2 mins then turn off since it drops water temp to like 150F ... its well worth it in a hottie.
Posted 04 October 2006 - 09:04 PM
#yep thermostat is working fine its a 180
#coolant is new as ive just flushed it all out.
#i have seen a few drops of coolant on floor which looks like its coming from the back of the motor.
#13 _1QUICK LJ_
Posted 04 October 2006 - 09:47 PM
Posted 04 October 2006 - 09:54 PM
you have to find and fix that leak before you proceed.#i have seen a few drops of coolant on floor which looks like its coming from the back of the motor.
#15 _devilsadvocate_
Posted 04 October 2006 - 10:07 PM
Posted 04 October 2006 - 10:25 PM
you cannot maintain pressure in a leaking system.
#17 _devilsadvocate_
Posted 04 October 2006 - 10:45 PM
In a system that maintains 80-5C, putting a radiator cap on it wont change the temperatures at the places it can be measured.........
Pressurisation doesn't increase heat transfer, it just raises the ranges of operating temperatures of the motor. One should aim to make the cooling system good enough that a rad cap is only needed for extreme circumstances.
Nucleate boiling I hear in the distance, phenomenon that is extremely difficult to detect if its happening or not(if you have preignition maybe)........possibly why its used as a reason to peddle water wetter etc..........if it was as much of a prob as suggested, coolant temperatures would be lower, not hotter.............
Posted 04 October 2006 - 11:29 PM
.............loosing pressure is what is typically making the drops come out in the 2nd place..........the pressure is what is typically making the drops come out in the 1st place.
is not the leak is the first instance?
#19 _MAWLER_
Posted 05 October 2006 - 10:17 AM
Posted 05 October 2006 - 02:53 PM
he could get one of theseAs the ebay add says danny, those later series water pumps have a l longer snout and will not fit with the old gear you have on the motor. If you were going to get one you would have to change all your pulleys to commodore as well.
http://cgi.ebay.com....1QQcmdZViewItem
#21
Posted 06 October 2006 - 06:47 PM
I got quoted $300 for a the vs radiator today. Is it worth changing to a vs rad and au fans plus ill be installing a new water pump while iv got the chance???
danny..
#22 _spud_
Posted 06 October 2006 - 09:41 PM
Also is the motor rebuilt?? cause if the motor is old you should rip out all the welsch plugs and literally flush your motor clean. If you flush your motor just in an out of the radiator hoses it won't do it properly. you will find their are little pieces of rust near the outside of the bores when you pull your welsch plugs out. they will cause the motor to not cool down properly. clean them out and you will find the motor will stay cool with a 2 core radiator.
Do you have and auto in this torana, and if so does it cool down through the radiator. cause that will cause major heating.
#23 _devilsadvocate_
Posted 06 October 2006 - 10:09 PM
Installing cross flow radiators from later models doesnt make any sense to me or are the vs radiators alloy?, the space on the torries is more suited to a vertical flow radiator..........having some trouble seeing ^ how you might keep a 355 cool with a 6cyl conventional 2 core.
Edited by devilsadvocate, 06 October 2006 - 10:22 PM.
#24 _Lostit_
Posted 07 October 2006 - 08:02 AM
Is it coming from the back of manifold? HAve the heads got welsh plugs at the rear? Or is it From Motor plugs from rear? Or is it actually from the block to Head gap?
Best thing i can suggested here is get your hands on a pressure tester..... If you dont know how to use it , these are the finer points .
Make sure engine is cool , Car is on level ground.... the ground underneath is clean . Plug in the pressure tester properly on top of radiator and pump it up ( i cant remeber pressure needed but im sure its easily found) Leave the pressure tester on the car for an hour roughly while reguraly checking if the gauge is losing pressure or not, if so check for where the visible leaks are coming from .
Hopefully they are all visible , if they are not visible and still losing pressure then its internally.
Once you can leave pressure tester on car for an hour or so without losing pressure , then we move onto next problem solving area.
One of the golden rules.. always fix the easy problems first .
Denis
#25
Posted 07 October 2006 - 01:16 PM
