Commodore LSD Diff's
#1 _77LXKID_
Posted 06 April 2009 - 05:04 PM
thanx to all of you at the forums. BRAD.
Posted 06 April 2009 - 06:18 PM
and the tailshaft was made to suit 3 inch from memory,200 for that
#3 _Squarepants_
Posted 06 April 2009 - 06:27 PM
The dude that did mine cut a section of axle tube out of the middle and sleeved them when rewelding. Saves cutting and welding flanges....just have to watch when re welding flanges on...
#4 _77LXKID_
Posted 06 April 2009 - 06:52 PM
#5 _The Baron_
Posted 09 April 2009 - 02:29 PM
That's all I know of, but I personally can not vouch for them.
Posted 10 April 2009 - 07:33 PM
Sorry, I dont get your drift. Axle tube? sleeved ? how does it save?
I assume Benno had flanges rewelded to keep the Torana stud pattern and hub on a VN axle.
Posted 10 April 2009 - 08:30 PM
doesnt seem right to me mate
#8 _mumstaxi_
Posted 10 April 2009 - 09:28 PM
Sorry, I also dont get YOUR drift. So how does just re-welding the flanges allow you to put Torana wheels on a VN stud pattern axel ?
would it not have to be a Torana axel as well, or you would need to modify the stud pattern on the VN axel to suit Torana wheels ?
MT
Posted 11 April 2009 - 08:11 AM
The axle tube is part of the diff housing which the axle runs inside of. The axle would still need to be resplined & have the stud pattern altered to suit Torana wheels.Sorry, I also dont get YOUR drift. So how does just re-welding the flanges allow you to put Torana wheels on a VN stud pattern axel ?
MT
Warren
#10 _Squarepants_
Posted 11 April 2009 - 01:55 PM
My diff still runs all Commode parts (incl. shortened axles, bearings, flanges) but has axles redrilled to suit Tory pattern.
Obviously I didn't explain myself properly. Any other questions?
What flanges were you talking about, Benno? Axle or axle tube?
#11 _mumstaxi_
Posted 11 April 2009 - 08:34 PM
thanks guys ,my point was, ol mate is obviously a bit confused or not explaining things correctly by suggesting a torana rim will bolt up to the VN stud pattern axel without more mods (ie more than only re-welding flanges)
MT
#12 _XU1-043_
Posted 12 April 2009 - 09:15 AM
back o topic though i haven't killed mine and my old man uses the same set up (shortened borgy) in his cobra and we haven't killed that either.
ps. to save a little money the short commodore axel can be used as you long axel after the diff is shortened then you only have to modify one axel.
#13 _Squarepants_
Posted 13 April 2009 - 09:12 AM
i've got a VN ute diff in my car, diff technics did it for me, they did a neat job the only thing i'm not completely happy about is the pitch of the diff centre. if i have two people in the car and really give it a hard time the diff hits the tunnel right where the tailshaft joins, i am going to put new springs in to try and stiffen the back end up to rectify the problem.
If you can, get some adjustable upper trailing arms so you can roll the diff forward.
#14 _XU1-043_
Posted 13 April 2009 - 09:58 AM
i was wondering if someone did that sort of thing. do you know anyone?If you can, get some adjustable upper trailing arms so you can roll the diff forward.
#15 _Squarepants_
Posted 13 April 2009 - 10:18 AM
Check out that thread. Not sure about LC/J ones but that should point you in the right direction.
