Dodgey method of removing stuck brake pipes.
Posted 24 July 2009 - 09:40 PM
A bit of a wire brush off.
A tap tap here
And a tap tap there
A big flat ended punch, in this case a bolt was used. And a hammer.
Best if you can hit two apposing flats on the hex of the flare nut. Each application will differ. Pick the easiest ones to get to, obviously, and if you can't get to apposing flats, any 2 you can get to will do, you just might have to tap a bit harder.
A bit of a squirt
A shifter AAAAAAHHHHGGGGGGGG!!!!!!!!!!!! RUFF AS GUTS!!!!........read on
Voila!!!
A good shifter is better than an open ender for a couple of reasons:
The jaws are wider.
Once fitted to the flare nut, you can tighten the shifter jaws to get the best fit on the flare nut.
A worn out shifter will be as useless as an open ender.
How the jaws close up together and how much the adjustable jaw wobbles is an indication of it's suitability.
Believe it?......
Or not!..........
Posted 24 July 2009 - 09:45 PM
Posted 24 July 2009 - 09:51 PM
Got them off a forum member. His dog dug them up in the back yard I think?
#4 _torana_umunga74_
Posted 24 July 2009 - 09:56 PM
Posted 24 July 2009 - 10:14 PM
they are WB front
Looking like that I probably would have put the pipe nut in the vice and turned the hose
Posted 24 July 2009 - 10:26 PM
Posted 24 July 2009 - 10:35 PM
Posted 24 July 2009 - 10:48 PM
Posted 24 July 2009 - 11:30 PM
Don't disagree, but surely you would own a set of hydraulics spanners?A good shifter is better than an open ender for a couple of reasons:
Posted 24 July 2009 - 11:35 PM
Cheap ones just spread and strip the nut anyway
Unless you can clamp some vice grips around them first to keep them together
Posted 25 July 2009 - 12:02 AM
I have paid good money for good quality ones in the past just to find they don't cut it.
I have had 2 with 4 different sized ends. I couldn't tell you where they are now.
#12 _HQ SS_
Posted 25 July 2009 - 12:32 AM
They come in 3 sizes.
A bit of lube and a rocking motion (tighten a bit/ loosen a bit) and off they come.
They give you 3 points of grip and a nice tight fit.
This has worked on about 98% of the tube nuts I have had to undo.
Cheers Paul.
#13 _torana_umunga74_
Posted 25 July 2009 - 01:18 AM
Posted 25 July 2009 - 12:45 PM
I bought three (six ends) just from Autobarn and they were about $20 for the set, all imperial. I haven't used them too extensively yet, mainly on fuel lines, only a little bit of brake work, but the difference I've found is unbelievable. I guess I'll find out whether they're really good in time...I have paid good money for good quality ones in the past just to find they don't cut it.
#15 _sbc57lx_
Posted 27 July 2009 - 06:09 PM
Posted 27 July 2009 - 06:52 PM
#17 _Skapinad_
Posted 27 July 2009 - 06:58 PM
Posted 27 July 2009 - 11:36 PM
These are the spanners that Red is talking about. Ive got a set and they are great!. Also can be made with a conventional ring spanner and a grinder.
Posted 29 July 2009 - 06:07 PM
Posted 29 July 2009 - 07:02 PM
rusty pipes on aircraft ? bloody qantas !
I don't work for QANTAS and I have never found a corroded pipe on an aircraft, especially since most are stainless or aluminium alloys, I was talking cars
#21
Posted 30 July 2009 - 06:10 PM
#22 _Bomber Watson_
Posted 31 July 2009 - 09:10 PM
I honestly dont know why people worry about it.
Posted 31 July 2009 - 09:19 PM
#24
Posted 31 July 2009 - 09:27 PM
Because it can be a prick of a job to flare a new end on the car (or remove the entire length of tube), and even more so if it ends up too short and needs replacing. If it ain't broke don't fix itDouble flaring tools are not expensive. Fittings for the end are not expensive. Brake tube is not expensive.
#25 _Bomber Watson_
Posted 31 July 2009 - 09:38 PM
Time to replace anyway.
But yes i get your point.
