Clints LH Project
#1 _Viper_
Posted 27 March 2006 - 10:51 PM
Got my 9" back in, painted, rebushed and Disk Brakes fitted.
New UC Front crossmember, powdercoated, new bushes and Hopper Stoppers brake kit.
And new Cragar SS 15x10" mags on the Rear with 295/50/15's
Just finishing off a couple of things with the crossmember and got a few other things to do then ill be fitting the motor and gear box, then will be sent off to the Auto Electrician for a complete rewire.
Its getting closer and closer to being finished, starting to get really excited. Anyway here's a pic, will get some more with the new crossmember etc asap.
-Clint
#2 _the gts_
Posted 27 March 2006 - 11:18 PM
do the 295's fit in the guards or is it tubed or gonna be flared
#3 _2wild4u_
Posted 28 March 2006 - 12:39 AM
#4 _[BOTTLEDUP]_
Posted 28 March 2006 - 02:58 AM
Keep us informed/updated with all the latest developments!
#5 _Viper_
Posted 29 March 2006 - 08:00 AM
And Gah goto work saturday and sunday this weekend so wont get much done, but Easter is coming up soon and I get a 5 day break so Should be a good time to make some progress
#6 _355lxss_
Posted 29 March 2006 - 11:42 AM
Posted 29 March 2006 - 12:00 PM
I think Viper should ewrite his how to fit commodore discs article so we can repost it up
#8 _Viper_
Posted 29 March 2006 - 09:48 PM
#9 _Viper_
Posted 30 March 2006 - 07:49 AM
-Clint
#10 _Herne_
Posted 30 March 2006 - 09:01 AM
Nice display mate.
Herne
#11 _355lxss_
Posted 30 March 2006 - 12:59 PM
Also are you running the big or small axle bearings with that rear brake setup?
#12 _Viper_
Posted 31 March 2006 - 07:56 AM
As for the axle bearings? ummmm I know there roller taper bearings... Never had much to do with Axle's so not sure if there the big or small type?
Lol Herne, thats the result of being bored And wanting to work on your car but you cant for various reasons...
Edited by Viper, 31 March 2006 - 07:58 AM.
#13 _Viper_
Posted 02 April 2006 - 11:29 PM
Engine:
308 Red with Top End Injected
ACL Race Kit
Balanced And Blueprinted
Flat Top Pistons
VN EFI Heads And EFI Manifold
Double Row Timing Chain
Gilmer Belt Drive
MSD 6AL Ignition
Pacemaker Extractors
Twin 2.5" Exhaust
Driveline:
TH700, Stage 2 Shift kit 2500 Hi-stall, B&M Megashifter
Ford 9" LSD Diff, 3.7 Gears, 31 Spline Axels
Suspension:
Reconditioned UC Front Crossmember, Powdercoated Gloss black
New Noltec Soft ride bushes all round
Koni Adjustable Suspension
Lowerd King Springs
Brakes:
Hopper Stoppers Front Brake Kit 290mm Slotted/Ventilated Discs with 2-Spot calipers.
Reconditioned Commodore Rear Disc Brakes
Braided Brake Lines
Body:
2-Pak Windsor Blue Paint with Tuxedo Black, Blackouts
A9X Scoop, A9X Flares and Front Spoiler
Chopped Guards
Yea thats about it i guess? Will be re-doing the interior also and have OBX Racing Seats for the Front, As well as Electric Windows and Central Locking and Alpine Stereo...
-Clint
#14 _Viper_
Posted 01 April 2007 - 01:57 PM
since I been working up north n earning the Big bucks haha I decided to take it to Extreme Performance and throw some money at it and get the thing going
Here's a Couple O Pics
On its way to the workshop
Custom Brake Lines
Had The Extractors Coated
Old Hole For Manual Shifter Patched & Megashifter Fitted
Thats about it for now, OH some will know the 308 I had built turned out to be junk... so I bought a complete VS 304 and will be building a Tuff 355 should be a beast... Forged internals, 4-bolt mains, Ported EFI heads, Solid Cam mmm cant wait!
-Clint
Posted 01 April 2007 - 05:39 PM
lol I hadn't even seen the update at the top of this page (a year ago!). I thought you hadn't touched it in two years bwahahahaha.
Now you will have to update at least once a fortnight
Will you have a console around that shifter?
#16 _Viper_
Posted 01 April 2007 - 06:51 PM
#17 _BoltZ_
Posted 01 April 2007 - 09:50 PM
#18 _Azza_
Posted 01 April 2007 - 11:04 PM
Posted 01 April 2007 - 11:09 PM
They can be my friend...... they can beLooking bloody fantastic there Clint... wish my brakes were that big!
#20 _BoltZ_
Posted 01 April 2007 - 11:12 PM
Hmmmm....They can be my friend...... they can beLooking bloody fantastic there Clint... wish my brakes were that big!
I'll get back to you on that once this engine business is sorted!
#21 _TJ253_
Posted 02 April 2007 - 12:31 AM
#22 _lj chev_
Posted 02 April 2007 - 06:55 PM
i would like to hear about how you adapted the commodore brakes to 9 inch.
#23 _Viper_
Posted 02 April 2007 - 09:35 PM
#24 _Viper_
Posted 27 January 2009 - 06:41 PM
Hmm since then I got a Strong 355 built by Dave at Extreme Performance specs as follows (from top of my head sorry)
Holden VT 304 Block
Converted to 4-bolt mains with ARP Main studs
Eagle 355 Stroker crank
Forged Rods and Pistons (off top of my head think they were Scat Rods and SRP Pistons?)
Hi-Energy Sump
Crane Solid 280-2 Cam
VN Heads, 245cfm @ .600" Intake, 187cfm @ .600 Exhaust, Bigger valves, Yella Terra roller rockers, ARP Head Studs
Harrop Single Plane Intake
MSD Billet Throttle Body
MSD 6AL, Blaster coil, MSD Leads and Billet Dizzy
Gilmer Belt Drive
PaceMaker Extractors
Other bits and peices I cant remember
So that was built and fitted then Sat at my place for quite awhile again hehe.
Finally picked up a TH350 Box, had it rebuilt and strenghtned with shiftkit and hi-stall.
Also got new brake lines fitted & Fitted a modified handbrake cable for the VN rear brakes
Twin 2.5" Exhaust fitted
Tailshaft modified/balanced/fitted
Some may have noticed it has a Carby fitted in the previous pic and not the MSD Throttle body... Its going to be running on Straight Gas Injection but its been recommended to run the motor in on petrol which Ill have to use Racing fuel as it has just over 11:1 compression to suit the Gas so a tempory fuel system has been setup using a boat fuel tank temporarily mounted in the boot and a Carter lift pump under the car...
The car will be run in on a Chassis dyno with the Carby/Petrol and then Send to RAGE Racing where the EFI Gas conversion will be done
Here's a pic of the Boat Fuel tank
Car will be sent to Steve's Paint Studio next after being recommended by Nathan/2Wild4U to have the guards chopped out to the max and the Flares/front spoiler and A9X bonnet scoop fitted as well as line up all the doors + panels...
Then to a sparky (anyone recommend someone in Perth?) to get the whole car re-wired and hidden as much as possible Then Upholstery and Gas conversion then down to the track
Haha see yas again in another year or hopefully ALOT sooner
Edited by Viper, 27 January 2009 - 06:43 PM.
#25
Posted 27 January 2009 - 07:13 PM
if you can please keep me imformed.
mark
