Nicks LH Restoration
#101
Posted 04 August 2012 - 07:44 PM
but i have had a few solid days on the car and lately and i have got a few things done.. i ended up trowing out the old rare spares rad support and buying an aussie restos one the fitment wasn't great but with abit of hammer and dolly work it finally got welded in. i still have to clean up the welds on it but it all fits well with the nose cone and bonnet catch also i have attacked the skirt where the charcoal canister is and the seal on the bottom of the guard. a few more spots to fix plenuim and the rear windscreen where the owner has done some realy bad repair, and then the body is done with leaving me with some badly rusted doors to fix lucky me
check out some pics
bonnet hinge section tacked in
rad support in
seal rust converted ready to weld in patch
And that's my update guys.. hopefully over the next few weekends i can get some more work done..
nick
#102 _toranatime_
Posted 05 August 2012 - 01:48 AM
Posted 05 August 2012 - 09:37 AM
With the gas flow when I done the bonnet hinge section I was going off the regulator where is sed "mig" on it witch
Is around 30-40 I found out later that it was way to much almost triple of what I needed. I think I just started using 10-12
And I am getting a much better weld. Welding is the biggest challenge I have ever done and I am pretty hands on bloke..
It's getting there slowly though but I think a auto darkening helmet is on my wish list next..
Nick.
#104 _baddad_
Posted 14 August 2012 - 06:04 AM
Looking good. I see you got he radiator support sorted out. Yep country Vic weather as good as Melbourne does not inspire a lot of work. How is the motor rebuild going?
Posted 14 August 2012 - 11:58 AM
Motor is pretty much in the corner of the garadge surrounded by crap I need to make room and strip it to send away for rebuild. Hopfully I can do all that before Xmas...
#106 _a.vas_
Posted 21 August 2012 - 12:21 PM
was a bit of a pain that section! just remember to trial fit the gaurd before you fully weld it in
keep up the good work, looking very nice
#107
Posted 21 August 2012 - 10:04 PM
#108 _toranatime_
Posted 15 December 2012 - 06:14 PM
I would strongly reccomend you get your self an auto darkening helmet and it will make welding seem much less daunting and easier, especially stop start welding which you use on panels. I have a Lincoln and a Miller helmet and both are great.. and expensive haha. But i am using mine every day. A cigweld WIA or unimig helmet would probably be great for about a $100.
The car really does look great, i can't wait to see the body work finished. If you keep it up it will look tops.
Posted 15 December 2012 - 09:00 PM
i did buy a auto darkening helmet, best investment i ever made makes welding allot easier..
the car is actually tucked in the corner of the garage i haven't touched it for a while. i did say to my self ill get stuck into it once my back yard is complete that way i can get my msz of my back. that's nearly done so now i want to really get stuck into it i want to finish the rust prep and paint under car and then send it to a panel shop things will move then.
#110 _Greavezy_
Posted 15 December 2012 - 11:55 PM
Just wondering, for your paint removal and you just using the graffiti removal disks you can pick up from bunnings? on just a 4inch grinder? I havnt started stripping on any big panels because im worried about heat and warping panels.
Thanks, keep up the good work.
Matt
#111
Posted 16 December 2012 - 09:27 AM
On larger panels I used paint stripper to remove the majority and then I hit it with 60grit on the orbital.
Others on here use 36grit on a large 7" grinder but you have to be very carful not to keep it in one spot for a long time as it creates alot of heat.
If I was doing it all over again I would blast the lot.
#112 _Greavezy_
Posted 16 December 2012 - 10:38 PM
Thanks Matt, i only used the strip discs in the engine bay as it was hard to get into places
Alright, thanks mate. Yea i would love to blast it just cant afford to. Yea i was thinking of buying a 7" multi speed polisher/buffer but was still worried about heat, might do what you do it get the paint stripper out.
#113
Posted 07 January 2013 - 03:36 PM
i had to finish off all the welds in the engine bay and weld in the bonnet hinge plates. with them dumied in place i put all the hang on panels on and everything seemed ok so i plug welded them in. i forgot to take photos as i was exited things where coming along. then first time ever mixing up 2k paint or painting.. i epoxy primed the bay. looking like a car sort of. and i also stone guarded the inner guards. my repairs need a skim of filler then hoping to high fill the engine bay.
i was wondering whats the GO with painting 2k at home? as i am hoping to paint the engine bay my self just to save on some panel shop costs.
some pics.
i forgot what it looked like with panels on
ill upload a few more pics later on
#114
Posted 07 January 2013 - 03:39 PM
#115
Posted 07 January 2013 - 04:07 PM
#116
Posted 07 January 2013 - 07:36 PM
Into it hopefully progress will start showing.
Panels where just on to see that I had the bonet hinge plate in the right spot. I done pretty well with the measurements.
#117 _toranatime_
Posted 07 January 2013 - 07:57 PM
#118 _Emu_
Posted 27 February 2013 - 08:52 PM
Any updates Nick?
#119
Posted 28 February 2013 - 02:36 PM
#120 _Emu_
Posted 28 February 2013 - 03:16 PM
Yes. It's a nice colour. Similar to the old holden Aquarius. My first LX was that colour. Loved it
#121
Posted 11 April 2013 - 08:29 AM
K frame out. Hard work by my self and I used 2 jacks instead of a engine crane that proved to be a challenge.
Made a trolley for her and off to the panel/paint shop she goes. I pretty much done most of the rust repairs only left the plenum and a couple more that
I just don't have the time to get to anymore. I was mento epoxy the entire car before it went but due to me expecting a baby in 4 months or so I didn't
Want to be painting with the wife around.. The car left me yeatrday and I am hoping to see it back in a few months.
Hopefully while the car is gone I can get stuck into the motor and k frame.
That's it for now ill keep an eye out for progress at the shop
And ill update as it happens.
Some pics
My collection after 14 months
K frame out
Waiting to get picked up.
And going
That's all for now hoping to see some realy progress soon.
#122 _LS1 Taxi_
Posted 11 April 2013 - 11:46 AM
Hi Nick,
Cool build mate.
Congrats on what you've done so far - looks great.
I like your dog, looks a nice guy.
Congrats on the baby too
#123
Posted 11 April 2013 - 04:18 PM
Looking good. If your rebuilding the front end try and get rubber bushes from kingswood country there well priced and imo the best around at the moment
#124
Posted 12 April 2013 - 06:56 AM
Hi Nick,
Cool build mate.
Thanks mate getting there slowly. And the dog always is in the auction when working on the car.
Wow its all coming along quickly now.
Cheers Steve, yeh it's happening but hopefully the completion comes quick as I've had enough of it sitting in the garadge.
Yeh front end will be getting redone with the hamburger kit I bought that a little while ago just have to get it stripped and all that.
I am not sure on what type of springs for ride hight to use though.
#125
Posted 12 April 2013 - 05:51 PM
Also tagged with one or more of these keywords: Lh torana restoration rust, restoration, rust, lx torana
Members Area →
Members Projects & Plans →
The Sally ReportStarted by _The Handbrake_ , 23 Jun 2019 LC GTR, Restoration, 1971 and 2 more... |
Holden Tech →
Paint & Panel →
Rust repairs in MelbourneStarted by _LCWannabee_ , 30 Mar 2018 rust, lc, repairs |
General →
General Discussion →
Resto Rage HelpStarted by Rainman , 16 Sep 2017 restoration |
Holden Tech →
General LH-LX-UC →
LH Torana rear windscreen SpecificationStarted by _Pjabrown_ , 06 Sep 2016 Lh, Torana, Restoration and 6 more... |
Holden Tech →
General LH-LX-UC →
Best paint to buyStarted by _toranaheath_ , 27 Oct 2015 paint, restoration, mint julep and 2 more... |
