So I thought if I could do the adjustment from in the Tory it would make it easier.
So what I made became History:-
- You make a profile bracket that fits the Dizzy Stem horizontally and extends 50mm further away with a vertical pivot hole for the clevis.
- drill a 6mm hole in the firewall that is levelled to the Dizzy bracket ( for the Rod to Pass through ).
- Make a lever (( 170mm long with adjustment holes ( short to long stroke )) with a pivoting point which fastens to the bottom of your Dash.
- With your Dizzy where the Engine Runs ok, measure from the Bracket ( which is parallel to the Firewall ) to the firewall and from your lever inside the cab ( Vertical ) to the firewall and add them together.
- make a Rod connection with the measurement having pivoting end connectors.
- Bingo, we can do a Self Timing Dyno.
It does not matter what you have done to the Motor ( Head, Cam etc ), this method gets the perfect Timing Position and you will Win Races.
p.s. You will run out of REV's as you try this, so slow down and get up it again and again until you feel the Tory going the best.
p.p.s. my engines, when you strobe light it after the Self Dyno Tune runs at 17 Degrees BTDC and I leave it there.
p.p.p.s. if you need a Drawing of this just yell.
