Just finishing up some bits 'n pieces with the front plate of the diff housing and getting some practice in with making hoses & piping too...
9'' Carrier in Front Plate 02.JPG 66.39K
0 downloads
Those hoses above will change once I figure out where the upper trailing arm mount goes so they're not the finished product, I really just threw them in for aesthetics.
Figured out where the oil level should be and made a filler plug with a sight glass, I was tempted to use an elongated sight glass so you can actually see where the level is rather than just whether it's full, but I'd be worried about a rock hitting it and letting all the oil drain out of the diff, do they make bullet-proof ones?
Also made a rough attempt at a temp sender but I've been looking around online for a combined temp and level sensor, found a few although nothing that really takes my fancy, I'd like both features but not separately. I made all four holes ¾" NPT anyway so pretty sure I should have room to adapt something later.
I'm still unsure if I need a separate sender to trigger the pump/cooler as well, I might be able to use the same one for pump and gauge if I can find a suitable controller, although that would give me adjustability it's just one more thing to go wrong so I might still need to rearrange the layout yet?
Made a neat looking little copper pipe to dump oil returning from the cooler onto the pinion, still undecided whether that's the best place for it and I'm open to suggestions? I think the absolute best place would be tapped into the snout of the case to positively oil the front pinion bearing, but I'm trying to stay away from modifying the case and just keep everything in the housing.
9'' Carrier in Front Plate 03.JPG 70.77K
0 downloads
I think I'd need to incorporate a one-way check valve in the system somewhere too, maybe in the pickup down the bottom, to stop all the oil draining back out of the plumbing and overfilling the diff.
The lower fitting could double as a drain plug but wouldn't ever get used, heaps easier just to disconnect a hose off the cooler and used the pump to do oil changes.
Nearly suspension time, following Heath's other thread with interest...
