Rare spares heater core
14 replies to this topic
#1 lh 4dr
lh 4dr
  • 54 posts
  • Name:dave
  • Car:lh sedan
Posted 14 November 2015 - 06:12 AM
Hi, i just got a new heater core from rare spares and split the heater box open and found the new core is a lot thinner then the origional. I had a 2nd heater box (1 lx and 1 lh) and it is thicker than the new one too. The hose inlet and outlet look ok but the core is too thin. Anyone else had this or is the heater core wrong. While on the heater box i did a search and there has never been a definative answer on the best foam/covering for the flap doors.
#2 lx308
lx308
  • 2,838 posts
  • Name:Tony
  • Car:Nuffin. Goin touring.
Posted 14 November 2015 - 08:55 AM
Yep. I bought one years ago, 2007-2008, & never used it because it was too thin.
#3 TerrA LX
Posted 14 November 2015 - 09:23 AM
Maybe shift this thread to the rares spares section????
#4 _les_
_les_
Posted 15 November 2015 - 10:24 AM
Better still contact Eden at Rare Spares via PM
#5 _The Baron_
_The Baron_
Posted 15 November 2015 - 07:12 PM
Been the same for years so this is not new...........news.
Still does the job just to as thick as original.
#6 _Muzzy_
_Muzzy_
Posted 15 November 2015 - 07:23 PM
Had one in now for nearly 3 years running on OAT coolant , no problems, I re foamed all the
doors with stuff from Bunnings
#7 lh 4dr
lh 4dr
  • 54 posts
  • Name:dave
  • Car:lh sedan
Posted 15 November 2015 - 07:26 PM
Yeah it probably will i am just trying to figure out the best way to mount it so its in securly so its weight isnt supported by the pipes
#8 EunUCh
EunUCh
  • 2,761 posts
  • Car:japos
Posted 15 November 2015 - 07:33 PM
or from post #366 on wards in this build thread.
http://www.gmh-toran...lr-5000/page-15
#9 mika03au
mika03au
  • 812 posts
  • Name:Michael
  • Car:LX hatch
Posted 15 November 2015 - 08:01 PM
Have done some.months ago. No change, still selling the wrong unit.
Only supplying the one with same size pipes. Earlier type had different pipe sizes.
http://www.gmh-toran...re/#entry910369
Edited by mika03au, 15 November 2015 - 08:03 PM.
#10 _Edan_
_Edan_
Posted 16 November 2015 - 01:59 PM
mika03au, due to your input we recognized initially we had an issue with regard to the description of our heater core #9939234, we have amended description some time ago to read 'LX UC WITH 2 X 5/8" PIPES'. We have tested our heater core in a heater box/car and you will be interested to know that the GMH drawing for this part does not denote any core thickness but only a performance requirement, it also states outlet pipe dimensional requirements. Due to the new technology available we believe our heater core has the same performance or better than the original cores though it has a thinner core which is concealed within the box.
The LH type is not listed on the GMH drawing we have however we do have an original sample in hand of this and we will likely consider reproducing in the future.
Edan
#11 mika03au
mika03au
  • 812 posts
  • Name:Michael
  • Car:LX hatch
Posted 16 November 2015 - 05:31 PM
Cheers Edan,the thickness of the core is somewhat important as it allows it to be secured in place by the heater box.
With the thinner core it is the heater hoses which hold the core secure in place.
Hope that explanation makes sense?
Also I think the pre ADR27a (LH and early LX) have the two different diameter pipes.
I hadn't checked the RSP site for any changes so good to see the clarification.
Attached File  image.jpeg   228.13K   3 downloads
Edited by mika03au, 16 November 2015 - 05:35 PM.
#12 EunUCh
EunUCh
  • 2,761 posts
  • Car:japos
Posted 16 November 2015 - 08:49 PM
Sheesh...i don't know..we should at least think our selves lucky that there is something available that will do the job..even if we need to use a little Aussie initiative to make it work despite what is involved in doing the job...the days of just getting one "off the shelf" are long gone.
Edited by EunUCh, 16 November 2015 - 08:49 PM.
#13 _LS1 Taxi_
_LS1 Taxi_
Posted 16 November 2015 - 08:53 PM
Nope.
At the prices charged by Rares they should be perfect...IMHO.
#14 Ice
  • 15,123 posts
Posted 16 November 2015 - 09:18 PM
At least they make them for you LH LX guys
#15 Ice
  • 15,123 posts
Posted 16 November 2015 - 09:22 PM
There not that expensive Daz cmon
