The LC 2 door... Quick lick and Flick
#51 _Caustic_
Posted 07 July 2016 - 12:29 PM
What I done different this time was to cut the shifter handle off the shifter for easier fitment into the Lc.Got the idea from my V8 4 spd which has got a removeable shifter handles fitted to it. I made a 1/2 unf collar and welded that onto my standard shifter so i could borrow the main shifter handleform my other box. I assembled 6cyl box gearbox on the bench got the gates nicely lined,made it an easier installion.
I now upto real time prgress with car.
#52
Posted 07 July 2016 - 01:32 PM
I wish mine were this quick.
Awesome by the way....
#53 _Caustic_
Posted 07 July 2016 - 02:49 PM
#54
Posted 07 July 2016 - 03:10 PM
#55 _Caustic_
Posted 07 July 2016 - 04:14 PM
You may remember, he also had a real tidy LC and also a LJ from memory.
#56
Posted 07 July 2016 - 04:20 PM
Lol, that was me, small world.
Great thread mate and your car looks really good.
#57 _Caustic_
Posted 07 July 2016 - 05:04 PM
Cheers again.
#58
Posted 07 July 2016 - 05:15 PM
#59 _Caustic_
Posted 07 July 2016 - 05:27 PM
cheers.
#60
Posted 07 July 2016 - 11:00 PM
Great looking car John.
Yes I did have some issues getting my car over, but nothing that was too hard to fix other than the steering being too heavy.
Third(fourth? can't remember) time lucky I found a guy who wasn't a d!ck and understood that the steering was actually pretty normal for the car.
I really thought for a while I had wasted my time and money, but it was all good in the end.
And regarding my comments about the gearbox, yes, Aussie 4 speed was definitely in LC from around mid-71 from memory, so probably not he same situation as having a Celica 5 speed which were never standard although you could be forgiven for thinking they were with the amount of cars that got the conversion.
What part of Perth are you in of you don't mind me asking?
#61 _Caustic_
Posted 07 July 2016 - 11:45 PM
#62 _Caustic_
Posted 08 July 2016 - 05:48 PM
#63
Posted 08 July 2016 - 06:23 PM
Hi ya John...
Great job and turned out amazing!! Pretty dam good for a quick lick and flick!!
Posted 08 July 2016 - 08:30 PM
#65 _Caustic_
Posted 08 July 2016 - 09:12 PM
#66
Posted 09 July 2016 - 05:51 AM
thanks for the reply,and thankyou for those parts,The front cross member was repaired and used in an LJ and I still have the diff for a VS/LC conversion I'll do later.Have you still got LJ,from memory its was real nice original car and you were in the process of selling your LC show car I think.
Cheers again.
Hi, Good to hear all the parts are being used again, I think I got that diff off ICE.
I still have both my cars although I have never got around to getting them licensed in Qld.
Keep up the good work.
#67 _Caustic_
Posted 17 July 2016 - 09:28 PM
#68 _Caustic_
Posted 25 July 2016 - 07:27 PM
#69
Posted 25 July 2016 - 08:31 PM
enjoy mate
#70 _Caustic_
Posted 25 July 2016 - 11:28 PM
#71 _Caustic_
Posted 06 August 2016 - 12:19 AM
Now for the Engine specs.
LH 202 motor,
Starfire rods,
YT 12000 head.
YT roller rockers.
Standard cam.
Approx 9.0 comp ratio.
Standard 202 carby.
VH electronic ignition.
Mixture of spark plug leads(as 2 were accidently thrown out).
Genie extractors 2"exhaust XU1 muffler
Boring I know,but its a start.
ambient dyno cell temp was 19'
My fuel mixture was approx 12:1.bit rich..we could of improved the total hp output by tuning the carb, but wasnt worth wasting dyno time on a stromberg.
And for those that dont know, all tests were performed in 4th gear. 1:1 ratio
As you can see from the graph the engine is responsive but runs out of fuel around 4200 rpm.
Total power 108 rwhp at 3700......room for improvement.
Im in the process of rebuilding the 350 Holley and will fit the camshaft that came with the car.Its new and the seller tells me it was an XU 1 cam. It has 951355 stamped on it. Any ideas anyone.
Ive order some bits from ebay once they arrive, I'll post some more updates.cheers.
#72 _Caustic_
Posted 10 August 2016 - 10:13 PM
Ive set the 350 carby up with 57 size jets and a 6.5" power valve,hopefully that will supply enough fuel for the 35/75 cam initially,until I can get a better fuel system.
Also started tidying up my engine bay,Amazing how bad, engine bays look in photographs.
Parts still havent arrived, so im just chipping away by freeing up 1/2 a day to work on the lc.
Funny,someone made an offer on it on monday,but Im starting to get attached to it.Id Just like to finish the car to what i think is it full potential.
cheers.
#73 _Caustic_
Posted 19 August 2016 - 10:59 AM
Also making the accelerator rods, which is 6mm mild steel rod which i bought from bunnings and ive threaded with a 1/4 unf die,as my accellerator setup uses threaded fittings.
#74 _Caustic_
Posted 19 August 2016 - 02:59 PM
#75
Posted 19 August 2016 - 06:52 PM
