Aircon and power steer
11 replies to this topic
#1 jeffblanco
jeffblanco
  • 349 posts
  • Name:Mando
Posted 01 November 2016 - 11:13 AM
Hi guys,
just wondering on your thoughts on whether to install air conditioning and power steering to a LX hatch that will have 10" rims to the rear and 8" rims to the front.
I would never take the car out on a day that was over 25 degrees or if the roads were wet.
Regards.
#2 Rockoz
Rockoz
  • 3,967 posts
  • Name:Rob
Posted 01 November 2016 - 03:14 PM
Dont know why you would restrict your driving pleasure like that but each to their own.
Search member axistr.
He has developed an engineered power steering set up which works very well.
He has also fitted aircon to his projects.
Look him in projects and be prepared for a long interesting read
#3 Ando
Ando
  • 519 posts
  • Car:6/'76 L32 SS white & black. 9/'76 L31 SS gold. 5/'77 L31 SS Chamois. 3/'79 UC SL Deluxe hatch.
Posted 05 November 2016 - 12:39 PM
I don't know how or why power steer & air con can restrict your driving experience but this is how I did it!
Most spanner swingers should be able to figure it out..it's not rocket science.
#4 _LS1 Taxi_
_LS1 Taxi_
Posted 05 November 2016 - 12:47 PM
I think the restricted driving pleasure remark was in regard to not driving the car if it is over 25 degrees or raining. I +1 that remark. Add a decent heater and air and drive the thing all year round!!
#5 Holdenbn74
Holdenbn74
  • 147 posts
  • Name:Brendan Nichol
  • Car:LH
Posted 05 November 2016 - 12:50 PM
I modified a HQ combo setup.
Bit of patience helps lol but worked well.
#6 Lima31
Lima31
  • 874 posts
  • Name:Lee
Posted 05 November 2016 - 01:34 PM
Hi guys, would it possible to get a close up of those set ups?
What pumps did you use?
#7 Holdenbn74
Holdenbn74
  • 147 posts
  • Car:LH
Posted 05 November 2016 - 01:38 PM
Sorry sold my 304 complete, running ls1 now.
Pump was SD508 chromed from evilbay.
#8 Sven
Sven
  • 31 posts
  • Name:Steven Goodwin
  • Car:LX Torana
Posted 05 November 2016 - 04:54 PM
Here is a link to axistr's air-con fit up.
http://www.gmh-toran...-project/page-5
#9 axistr
axistr
  • 1,169 posts
Posted 06 November 2016 - 06:57 PM
G'day Jeff, I try to get one of the torries out at least once a week,  Your right with a v8 up front and extractors even on a 25 deg day it doesn't take long for the cabin temp to  climb well over 30 deg. I can get my cabin temp down to 23 deg on a 40 deg day. With the way I set up my A/C I can have heated air con air which keeps it toastie worm inside but more importantly dry so the windows don't fog up. We use both cars rain or shine just not the hail part, we rarely drive with the windows down. The power steering is a straight forward conversion. I might be getting a bit soft in my middle age but I wouldn't take them out much either with out the power steering. I built the cars to be used and enjoyed and now my wife and kids love to drive them  all year round. When the LH was an immaculate stock 173 auto all original, after a month no one in the family wanted to take it out, they got hot and bored, it took the mod cons to get them excited again so it wasn't a dramatic change from their daily drivers.
#10 _pborg8_
_pborg8_
Posted 13 March 2017 - 08:40 PM
Hi Ando  was just viewing your post on how you mounted your air con . can you point me in the right direction where you got your brackets from and what size compressor you are using cheers
#11 Ando
Ando
  • 519 posts
Posted 14 March 2017 - 07:49 AM
Hi Paul,
The compressor is a Sanden SD5H09.
Bracket is a LH/LX alternator, reversed with spacers to low mount the compressor.
I made the 5mm stainless PS pump mounting plate. It also secures 4 head bolts, spacers & the 2 compressor bolts & spacers.
The pump pivots on 1 bolt & 2 bolts in slots to tension the V belt.
The black plate with idler pulley is a modified alternator plate design which also picks up the 2 compressor bolts.
I used all 4 end of head bolt locations to attached the assembled unit.
The rest is trial & error..
Hope this helps.
#12 _pborg8_
_pborg8_
Posted 05 May 2017 - 07:07 AM
Thanks to all the reply's all sorted cheers
