top ball joint
8 replies to this topic
#1 slack one
slack one
  • 54 posts
  • Name:Gary Carter
  • Car:looking for one
Posted 14 February 2017 - 11:39 AM
hi all i have put new top ball joints in a uc torana. The problem is when the wheels are turned left or right the wheel hits the top control arm with 16 and 18 inch wheels it looks like the stub axle needs to go on further .There is a gap of about 10mm  between the rubber and the stub axle. thanks Gary.
Edited by slack one, 14 February 2017 - 11:50 AM.
#2 slack one
slack one
  • 54 posts
  • Name:Gary Carter
Posted 14 February 2017 - 11:55 AM
trying to put on a photo.thanks gary.
#3 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 14 February 2017 - 12:32 PM
What is the part number of the balljoint?
#4 slack one
slack one
  • 54 posts
  • Name:Gary Carter
Posted 14 February 2017 - 12:42 PM
Hi vic sorry thru out the box. I was told  hr to hq were all the same but it seems to me the stab axle is not on far enough. i brought them from repco some time ago and i fitted them to the top control arm.and now i am putting it all together. seem to have a problem putting on photos can someone help please.thanks gary ( found a empty box says bj94 if that helps)
Edited by slack one, 14 February 2017 - 12:53 PM.
#5 S pack
  • 15,538 posts
Posted 14 February 2017 - 06:00 PM
Appears BJ94 suits Fords.
Personally I would piss off those ball joints with the nylock nuts and get ones with the original type castellated nuts and split pins.
Edited by S pack, 14 February 2017 - 06:04 PM.
#6 slack one
slack one
  • 54 posts
  • Name:Gary Carter
Posted 14 February 2017 - 08:16 PM
hi s pac that was a box i had in the carage but its not to say the ball joint came in that box.will be having a look around tomorrow and see whate i can get. i just dont want to have the same problem i have now if it is the ball joint. will take the ball joints out tomorrow and see if i can find and old one  and match them up and see what happens  i know the part numbers are bj54 but where can i get the ones with the castellated nuts a split pins. thanks Gary.
#7 S pack
  • 15,538 posts
Posted 14 February 2017 - 08:45 PM
Some info in this thread
http://www.gmh-toran...og-ball-joints/
#8 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 15 February 2017 - 03:37 PM
If possible, take the stub axle and ball joint to Repco, Bursons etc and ask to try the correct ball joint before you hand over any money. That will only cost you time and petrol money.
#9 arrimar
arrimar
  • 3,122 posts
Posted 15 February 2017 - 05:34 PM
BJ94 has three boltholes, toranas four.
