Aussie 4 speed lock up?
53 replies to this topic
#51 RallyRed
  • 7,843 posts
Posted 07 August 2018 - 11:36 AM
When you do something Col you do it good and proper. :spoton:
I'd still be checking that when in 1st gear the input shaft turns a smidgen past 2.5 turns to every turn of the output shaft.
Edited by RallyRed, 07 August 2018 - 11:37 AM.
#52 Bigfella237
  • 4,377 posts
Posted 07 August 2018 - 03:31 PM
You would need a couple of degree wheels to get much more accurate than that ^
Or just count the teeth and do the math... as set out in CAMS H2-3 (attached below):
Ratio   No.Teeth
2.54     25 29
         --x--  = (25 / 19) * (29 / 15) = 2.5438596491228070175438596491228
         19 15
1.83     25 25
         --x--  = (25 / 19) * (25 / 18) = 1.827485380116959064327485380117
         19 18
1.25     25 21
         --x--  = (25 / 19) * (21 / 22) = 1.255980861244019138755980861244
         19 22
1.00     Direct
Reverse:
2.54     25 27
         --x--  = (25 / 19) * (27 / 14) = 2.5375939849624060150375939849624
         19 14
#53 RallyRed
  • 7,843 posts
Posted 07 August 2018 - 05:47 PM
Ratio   No.Teeth
2.54     25 29
         19 15
1.83     25 25
         19 18
1.25     25 21
Yep..didntvwant to crack it open after they sealed it up so well..so just counted I/P splines  and Output splines and did the maths for 360 degree turn of input.
         19 22
1.00     Direct
Reverse:
2.54     25 27
         19 14
#54 RallyRed
  • 7,843 posts
Posted 07 August 2018 - 05:50 PM
yeah..just counted the Input & Output shaft splines, and did the maths in each gear, for 1 x 360 degree turn of I/P shaft.
    Bing (1)
