LX hatch seal channel rust repair
rust hatch seal channel
32 replies to this topic
#26 Toranamat69
Toranamat69
    Forum R&D Officer
  • 2,117 posts
Posted 18 July 2020 - 09:16 PM
Well I didn't have the current one to line up but it is different to all 3 corner pieces and the inner and outer lip are parrallel so still far from correct.
#27 Toranamat69
Toranamat69
    Forum R&D Officer
  • 2,117 posts
Posted 18 July 2020 - 09:24 PM
I just went and looked again vs the first pic in this thread and it is different actually. It is even taller on the outter lip than the first pic. I think it needs to be shorter. But yes I wont use any of them.
For my lx, I'm going to keep original and fix the couple of rust bubbles. For my UC, I'll wait or make my own if I get there first.
#28 Toranamat69
Toranamat69
    Forum R&D Officer
  • 2,117 posts
Posted 18 July 2020 - 09:30 PM
Ahh I see Brett's photo of one above now. Very different again so does that make 3 types from Rare Spares now?
#29 Toranamat69
Toranamat69
    Forum R&D Officer
  • 2,117 posts
Posted 18 July 2020 - 09:53 PM
Tough little devil to photograph.
Attached File  108155785_10222991106987663_8605378246591853249_o.jpg   31.97K   1 downloads
Attached File  107827792_10222991106827659_8532675535594725368_o.jpg   31.77K   1 downloads
#30 rodomo
  • 17,999 posts
Posted 18 July 2020 - 11:02 PM
1/2" square bar is you starting point. ;)
#31 Com_VC
Com_VC
  • 411 posts
Posted 26 July 2020 - 12:03 PM
How long is that piece and are the correct dimensions available for it?  What thickness? Is it just a straight section or is it curved?
Doesn't look that difficult to make up?
#32 Toranamat69
Toranamat69
    Forum R&D Officer
  • 2,117 posts
Posted 26 July 2020 - 02:32 PM
The straight section on my lx is approx 1030 to 1040 long and yes it is dead straight.
The rares straight bit I have here is 1128 long.
The rares corners have about 50 to 60mm of straight section on the ends so if you could use these, you would only need about 940 long straight. I guess if it is made 1040 long, some lucky people might get away with keeping their original corners.
Doesn't look hard to make. If I used the rares one above and cut the outside lip, I reckon it would be spot on with another 2.5 to 3mm lip folded over.
M@
#33 Toranamat69
Toranamat69
    Forum R&D Officer
  • 2,117 posts
Posted 26 July 2020 - 02:42 PM
HatchssV8 posted a piece of original Torana at top of page 1. Surely this would be the best bit to copy wouldn't it?
It may be that it depends which rubber seal you go for would call for a slight different channel.
