under steer
#1 _LX8VD69_
Posted 11 October 2006 - 08:08 PM
#2 _rorym_
Posted 11 October 2006 - 08:17 PM
Throw the rear bar away..get a stiffer front bar...Problem solvered!
Rule of thumb...
Understeer...lots more front sway bay
Oversteer (Fords)..BIG rear swaybar.
These are basic settings but you get the idea and...it works!
#3 _CHOPPER_
Posted 12 October 2006 - 12:07 AM
#4 _LX8VD69_
Posted 12 October 2006 - 01:43 AM
#5 _82911_
Posted 12 October 2006 - 07:02 AM
I have no further comments at this time........
Cheers Greg..
#6 _rorym_
Posted 12 October 2006 - 07:06 AM
#7 _LX8VD69_
Posted 12 October 2006 - 09:34 AM
WTF?^^^ WRONG!
Cheers Greg..
#8 _82911_
Posted 12 October 2006 - 10:56 AM
don't worry about it! nothing to do with you..WTF?
To help you further i need you to do a couple of things...
1st: is the car used mainly road or mainly track?
2nd: are you prepared to compromise the road performance/tyre wear to gain some track performance?
3rd: read this page...
Understanding oversteer/understeer
Then post your questions i will be pleased to assist you LX8VD69
Cheers Greg..
#9 _rorym_
Posted 12 October 2006 - 11:19 AM
#10 _LX8VD69_
Posted 12 October 2006 - 11:54 AM
#11 _rorym_
Posted 12 October 2006 - 04:37 PM
#12 _CHOPPER_
Posted 12 October 2006 - 07:45 PM
L34 specs are crap. Negative castor and virtually zero camber. If it was set there, install ( 3 ) 1/8" shims in each front position and ( 4 ) 1/8" shims in each rear position and get the toe in re-set. Just don't drive it too far between installing the shims and re-setting the toe-in. Ideally, do it in their carpark if they don't mind. Getting the wheel alignment fined tuned is much cheaper than buying a new sway bar.the wheel alignment was done recently and i believe to L34 specs. wasnt the idea behind the rear sway bar to stop oversteer?
